I am new to matlab , i am trying to simulate a simple circuit to check my calculation I have done on paper.
The circuit is the following, it has a gyrator and couple resistors.1 amp is flowing into the circuit.You can see the node names on matlab picture. enter image description here
I got the following equations:
Solved with calculator:
The results:
I built the circuit in matlab simulink but i got different results there. I am pretty sure missing something. Here is the matlab circuit: enter image description here
Values for the resistors and gyrator set correctly, the names show the resistors resistance. Gyrator conductance set :3.141592654
My problem is that i get different values for the nodes' potential not even close to that i have calculated.
So if you canfind what i am missing please tell me. Thank you
    \$\begingroup\$ If solver A doesn't equal solver B then make a very, very simple circuit to solve and it should be obvious which method is correct. \$\endgroup\$ – Andy aka Mar 17 '18 at 19:30
  • \$\begingroup\$ What are \$\gamma\$ and \$\psi\$ suppose to represent? There's inconsistent notation in your equations. You appear to be switching variables. \$\endgroup\$ – user103380 Mar 17 '18 at 19:31
  • \$\begingroup\$ @Andy aka I have used matlab for solving a circuit that had more components then this. I am almost certain ,becaused i checked couple times ,that i didn't miss calculated or something. The problem is in my matlab skills . \$\endgroup\$ – Levente Bartos Mar 17 '18 at 19:41
  • \$\begingroup\$ @KingDuken Sorry for the various names for the variables. The psi and phi represents node potential relatively to 0V. I used psi on the calculator and phi on the matlab and the hand drawed circuit. Sorry for that . \$\endgroup\$ – Levente Bartos Mar 17 '18 at 19:43
  • \$\begingroup\$ @KingDuken I suppose the thing you think is a gamma that is actually is the gyrator conductance ,little r. \$\endgroup\$ – Levente Bartos Mar 17 '18 at 20:11
The problem is you missed the units of the gyrator. Your calculations were for resistance while the simscape gyrator is in Siemens
So you need to enter \$\frac{1}{\pi}\$ instead of \$\pi\$
  • \$\begingroup\$ Thank you for pointing that out! That solved the problem and now the simulation shows the calculated results : ) \$\endgroup\$ – Levente Bartos Mar 17 '18 at 21:55
