I've been watching a YouTube video and wondered how the circuit lit an LED just by heating up a coil with a lighter.
Here's the circuit diagram. "Copper wire" is the coil I'm referring to.
(from https://youtu.be/ZoCRG1vK_38?t=7m5s)
Here's the photo of the coil being heated and an LED lit.
My guess is,
  1. the coil was heated up.
  2. electrons in the coil were released by thermionic emission, creating a positive electric potential in the coil.
  3. a very tiny current flew from the coil to one of the transistors.
  4. the current was amplified by the two transistors and drove the LED.
But I'm not sure about the thermionic emission. The most famous example would be a vacuum tube but that is vacuum. This one is in the atmosphere.
Am I correct? If not, how does this work?
    \$\begingroup\$ @dixhom: Take a screengrab of the circuit schematic in the video and add it to your question. A screengrab of the lighter under the coil would also help. \$\endgroup\$
    – Transistor
    Mar 19, 2018 at 12:13
    \$\begingroup\$ Flames conduct electricity and the hand holding the lighter is touching the metal frame of the lighter....... \$\endgroup\$
    Mar 19, 2018 at 12:58
    \$\begingroup\$ Note that the power to make the LED light up is NOT coming from the flame or coil. It is coming from the 9V battery on which the circuit is mounted. The circuit can make the LED light up when even an extremely small current flows into the base of the left transistor. It's a crappy circuit as well as there's no protection resistor in series with the gate. The 330 ohm resistor is to small value as well. The experiment is similar to saying a car is amazing because a small force on the gas pedal makes the whole car move at speed. \$\endgroup\$ Mar 19, 2018 at 13:12
    \$\begingroup\$ @Bimpelrekkie that's why cars are amazing... \$\endgroup\$
    – Arsenal
    Mar 19, 2018 at 13:18
    \$\begingroup\$ @BeB00 have you ever touched the input to an audio amplifier and listened to the speakers? \$\endgroup\$
    Mar 19, 2018 at 13:40
There's not a lot to go on but I would guess that the flame conductance is connecting the finger and thumb of the person holding the lighter (via the metal of the lighter) to the base of the first transistor. If you touch the input of an audio amplifer you normally hear hum/noise through the speakers so the same sort of thing is happening here; interference pick-up on the persons body is forcing some small current into the base and turning on/off the transistors (and LED) at 50/60 Hz.
The coiled up wire on the base is just to provide more surface area to the flame to get a "better" connection.
My guess is also that if a wooden match were used (instead of the lighter) the LED probably wouldn't light.
You have to be aware that a transistor with the base open like that is highly sensitive to any electrical noise on the base. With the base floating the leakage current through the collector becomes a slight bias current which makes the thing very sensitive to any excitation on the base wire.
Further, with that circuit, you have a current gain of somewhere in the region of 10,000. That means you need much less that a MICRO-amp of base current for the LED to have a noticeable brightness.
Adding a flame does a number of things.
It adds a conductive path between the users fingers and the base which, as Andy mentions, couples in whatever EMI the user is picking up. Since the base is so sensitive and the gain so high, you do not need much noise current to light the LED. This is especially true when he is holding the battery with his other hand creating a nice loop.
Further, the heating itself creates an excess of highly excited free electrons in the hot wire which are much more easily disturbed by surrounding EMI or whatever fields the moving charged particles in the flame itself may create.
