So I have this voltage regulator circuit. Applying the voltage divider,
Vadj=R2/(R1+R2) * Vout
then
Vout = Vadj * (R1+R2)/R2 = Vadj * (1 + R1/R2).
Why every site shows Vout = Vadj * (1 + R2/R1)?
Am I doing something wrong?
  • \$\begingroup\$ You are confusing Vadj with Vref \$\endgroup\$
    – Trevor_G
    Mar 19, 2018 at 20:01
You are confusing Vadj with Vref.
The device setps up Vref between the right output pin and the adjustment pin.
As such the current through R1 is
\$I_{R1} = V_{REF}/R_1\$
So, ignoring the small adjustment current through the device for now..
\$V_{OUT} = V_{REF} + I_{R_1} * R_2\$
\$= V_{REF} + V_{REF} * R_2 /R_1 \$
\$ = V_{REF}(1 + R_2 /R_1)\$
Of course in reality you need to add in \$I_{ADJ} * R_2\$ to that.
  • \$\begingroup\$ Thanks! I found where I started to confuse things, but I didn't fully understand. Is the current through R1 passing R2 also? Isn't there a current node where it splits throug adj and R2? \$\endgroup\$
    – Lowrdson
    Mar 20, 2018 at 18:57
    \$\begingroup\$ So I did a little bit more research after your answer gave me something new to search. After one hour of researching I opened the LM317 datasheet, and at basic circuit operation everything was explained. I wrote down Kirchhoff's law on the output and the result is exactly the equation that I didn't understand in the first place. Thank you very much for your help! \$\endgroup\$
    – Lowrdson
    Mar 20, 2018 at 19:31
