I have a non-inverting, single-supply, variable gain op-amp circuit configured in accordance with this diagram:
non-inverting opamp
(source: electronics-tutorials.ws)
  • Vcc: +16V
  • \$R_f = 800\text{ k}\Omega\$ Potentiometer
  • \$R_2 = 100\text{ k}\Omega\$
I have the potentiometer set to \$\approx 200\text{ k}\Omega\$ for a gain of:
$$ A=(1+R_f/R_2)=(1+200k/100k)=3 $$
I have confirmed that this works experimentally (A=3.07). However, what puzzles me is that when \$V_{\text{in}}\$ is left floating I get an output of 6V instead of approx. 0V. Consequently, any input below approx. 2V yields no change in output.
Per the datasheet for this op amp, the maximum \$V_{\text{os}}\$ is 5mV, which even when amplified by 3, is nowhere near 6V.
Below is a drawing of my circuit:
  • \$\begingroup\$ The op amp is only specified for dual voltage operation. How are you providing the bias voltage for the inputs with a single supply? With the input floating, there is no path for the op amp bias current. Thus the output cannot be determined. Note that a floating input is not the same as a 0 volt input. You need to provide a complete circuit so that we can better comment on its operation. \$\endgroup\$
    – Barry
    Mar 21, 2018 at 0:30
  • \$\begingroup\$ @Barry Thank you for the reply. I did not know that this opamp was dual supply only. Would a dual-supply allow the output to "rest" at 0V? For the bias current, I think I understand what you mean because the way that I tested the gain was by connecting points a and b together which would provide current to the non-inverting input. \$\endgroup\$ Mar 21, 2018 at 1:04
Extracts from the NTE941M data sheet: -
  • Common Mode Input Voltage Range is typically ±12 V on a ±15 V supply.
This means that if one supply of the op-amp is ground (0 volts) then you must have your input signal greater than typically 3 volts above ground or all bets are off.
  • Output Voltage Swing (for RL ≥ 10kΩ) is typically ±14 V on a ±15 V supply.
This means that you cannot expect the output to get any closer to the 0 volt rail than typically +1 volt above it.
Do you understand why now?
  • \$\begingroup\$ I think so. I'm going to need a more precise amp that gets closer to the 0V rail. \$\endgroup\$ Mar 21, 2018 at 17:03
  • \$\begingroup\$ @user3578834 you will find quite a few op-amps that can have their inputs work below the negative rail but you won't find any op-amps whose output goes below the negative rail and it usually falls short by a few tens of millivolts and even more when loaded. \$\endgroup\$
    Mar 21, 2018 at 17:08
