I am trying to make a circuit that can store the first and last value from a series of values. To do this I'm guessing I need a component to determine if it's the first or last value and this is what I'm struggling to find.
The data is arriving from an ADC, which is converting a spiromoteter analogue signal into digital. Each binary value of flow is inputted on a bus (with bits in parallel). My aim is to do numerical integration (Simpson's rule) for this I need to add the first and last values together.
Thank you.
  • \$\begingroup\$ Way too little information. How does the data arrive (is there a valid signal etc etc), in what format, when does the sender know what is the last input, what is the level of detail you need the answer to be etc. \$\endgroup\$ – DonFusili Mar 21 '18 at 12:53
  • \$\begingroup\$ Define first and last. Storing something is easy; retrieving it can be more problematic. A series of inputs - a plurality of inputs? \$\endgroup\$ – Andy aka Mar 21 '18 at 12:53
  • \$\begingroup\$ You need to provide a lot more detail about the nature of the data stream, e.g. voltage levels, timing, what separates different series of inputs, etc. before this question can be answered. \$\endgroup\$ – crj11 Mar 21 '18 at 12:55
  • \$\begingroup\$ What's the protocol for the ADC datastream? \$\endgroup\$ – DonFusili Mar 21 '18 at 13:00
  • \$\begingroup\$ Thank you for your replies, I have added more detail. If you need to know anything else, let me know. \$\endgroup\$ – Redjman Mar 21 '18 at 13:01
Assuming you're sure you need this, your code would probably look something like this:
p_main: process(clk, reset_n)
  type flowstate is (initial, gathering);
  variable r_state : flowstate;
  variable r_first_val : integer range 0 to c_max;
  variable r_second_val : integer range 0 to c_max;
begin
  if reset_n = '0' then
    r_state := initial;
    r_first_val := 0;
    r_second_val := 0;
    first_val_output_signal <= 0;
    second_val_output_signal <= 0;
  elsif rising_edge(clk) then
    -- determine if the input is valid, depends on protocol
    if inputsvalid then
      case r_state is
        when initial =>
          r_first_val := received_input;
          r_second_val := received_input;
          r_state := gathering;
        when gathering =>
          -- determine if the gathering is done, depends on protocol
          if finished_gathering then
            r_state := initial;
            -- go back to initial state
            first_val_output_signal <= r_first_val;
            second_val_output_signal <= r_second_val;
          end if;
      end case;
    end if;
  end if;
end process;
As you can see, much would depend on the actual protocol the data uses. You mention a bus, but not what kind of bus. Determining what data is valid and how to signal to other blocks/processes that you updated the output signals depends on your application.
