This is a high voltage Joule Thief circuit simulation I developed in LTSpice. I am sure that it qualifies as a true Joule Thief because, in the picture below, we are zoomed into the "dead" voltage area where light is still being produced, the area from 0.8-volts-per-cell (4x0.8=3.2v) and 0.5-volts-per-cell (4x0.5=2.0v), which is quite dead, according to usual battery expectations and individual cell voltage. Yet we're still putting out about 10mA RMS at each LED. I have tried to make a more efficient Joule Thief, and here is my question.
Higher voltage seems to make a more efficient Joule Thief, up to a point. You will see in the screen shot, efficiency calculations for powering strings of LEDs with different numbers of LEDs in them. What's really going on here, and how can we improve the efficiency even more?
FOR 3 LEDs, (D1-D3 and R1=15.000K) 613.12mW / 714.21mW = 85.85 % Efficiency
FOR 4 LEDs, (D1-D4 and R1=14.135K) (SHOWN) 613.98mW / 714.19mW = 85.97 % Efficiency
FOR 5 LEDs, (D1-D5 and R1=13.410K) 607.05mW / 714.26mW = 84.99 % Efficiency
For this 6-volt 4-Cell Joule Thief... Why does efficiency go up from 3 to 4 LEDs? Why does efficiency start going down at 5 LEDs, and how do we make the most efficient Joule Thief?
If it seems like I'm asking too many questions, I'm actually not sure what question to ask, because I don't know what I'm missing.
Also, (and I'll move this to a different question on this site) there seem to be really two concepts of efficiency here, an "instantaneous" efficiency, which changes per voltage and resistor settings, and an overal battery-life-efficiency or energy-usage-efficiency, which would put a figure on how efficient a store-bought resistor regulated flashlight would be compared to a Joule Thief, or even a constant current regulated flashlight. The closest I could come up with a way to test this kind of efficiency is to charge up some supercapacitors to the same voltage point and let the flashlight use the energy however it wanted, to see how long they last. So what are the industry terms used for these kinds of efficiency?
Here is a screen shot that describes the nature of my question:
and here is the LTSpice simulation file (*.asc) so that you can play with it:
Version 4
SHEET 1 1364 680
WIRE -160 -64 -272 -64
WIRE 64 -64 -160 -64
WIRE -160 -32 -160 -64
WIRE 64 -32 64 -64
WIRE -272 0 -272 -64
WIRE -240 0 -272 0
WIRE -224 0 -240 0
WIRE -272 64 -272 0
WIRE -160 64 -160 48
WIRE 272 64 256 64
WIRE 288 64 272 64
WIRE 64 80 64 48
WIRE 112 80 64 80
WIRE 224 80 176 80
WIRE 256 80 256 64
WIRE 256 80 224 80
WIRE 304 80 256 80
WIRE 400 80 368 80
WIRE 496 80 464 80
WIRE 592 80 560 80
WIRE 864 80 656 80
WIRE 64 112 64 80
WIRE -160 160 -160 144
WIRE 0 160 -160 160
WIRE 224 160 224 80
WIRE -272 240 -272 144
WIRE 64 240 64 208
WIRE 64 240 -272 240
WIRE 224 240 224 224
WIRE 224 240 64 240
WIRE 864 240 864 80
WIRE 864 240 224 240
WIRE -272 256 -272 240
FLAG -272 256 0
FLAG 272 64 D1
FLAG -240 0 V1
SYMBOL ind2 -176 -48 R0
WINDOW 0 44 73 Left 2
WINDOW 3 45 46 Left 2
SYMATTR InstName L2
SYMATTR Value 220µH
SYMATTR Type ind
SYMATTR SpiceLine Rser=0.001 Rpar=0 Cpar=0
SYMBOL ind2 80 64 R180
WINDOW 0 67 40 Left 2
WINDOW 3 38 66 Left 2
SYMATTR InstName L1
SYMATTR Value 220µH
SYMATTR Type ind
SYMBOL voltage -272 48 R0
WINDOW 3 -64 132 Left 2
WINDOW 123 0 0 Left 2
WINDOW 39 0 0 Left 2
WINDOW 0 34 58 Left 2
SYMATTR Value PULSE(0 6.2 0 5ms 10ms 5ms)
SYMATTR InstName V1
SYMBOL npn 0 112 R0
SYMATTR InstName Q1
SYMATTR Value 2SCR533P
SYMBOL res -176 160 M180
WINDOW 0 36 76 Left 2
WINDOW 3 36 40 Left 2
SYMATTR InstName R1
SYMATTR Value 14.135K
SYMBOL LED 304 64 M90
WINDOW 0 -5 30 VBottom 2
WINDOW 3 77 40 VTop 2
SYMATTR InstName D1
SYMATTR Value NSPW500BS
SYMBOL schottky 112 64 M90
WINDOW 0 0 32 VBottom 2
WINDOW 3 32 32 VTop 2
SYMATTR InstName D99
SYMATTR Value 1N5817
SYMATTR Description Diode
SYMATTR Type diode
SYMBOL cap 208 160 R0
SYMATTR InstName C4
SYMATTR Value 22nF
SYMATTR SpiceLine V=50 Irms=0 Rser=0.008 Lser=0
SYMBOL LED 400 64 M90
WINDOW 3 106 36 VTop 2
SYMATTR InstName D2
SYMBOL LED 496 64 M90
SYMATTR InstName D3
SYMBOL LED 592 64 M90
SYMATTR InstName D4
TEXT -120 -48 Left 2 !K1 L1 L2 1.00
TEXT -256 224 Left 2 !.tran 20ms startup
and here is the LTSpice "Plot" file (*.plt) to set up the graphing:
[Transient Analysis]
Npanes: 1
traces: 4 {524290,2,"V(D1)*I(D1)"} {524291,2,"V(V1)*I(V1)"} {268959748,0,"V(v1)"} {303038469,1,"I(D1)"}
X: ('m',0,0,0.002,0.02)
Y[0]: (' ',1,0,0.6,6.6)
Y[1]: ('m',0,-0.02,0.02,0.18)
Volts: (' ',0,0,1,0,0.6,6.6)
Amps: ('m',0,0,0,-0.02,0.02,0.18)
Units: "W" (' ',0,0,1,-2,0.5,3.5)
Log: 0 0 0
EDIT #1
To show that this is not just "noise" and is found elsewhere, here is a shot that (to me) shows this happens with a Buck converter chip (and, wow, shows 98 percent efficiencies are attainable) -- (the graph on the right). Even more graphs are in the datasheet, for different-sized inductors.
Furthermore, here is a picture of a 6 LED version, with the constant 6.2 volts I used in making my test figures. The figures for the 6-LED version are 594.96mW / 714.17mW = 83.31 % Efficiency. As I hope you can see, the efficiency starts to plummet the more LED's you add. Of course, at 6 LED's, we're having to pump up the voltage from 6.2 volts to 19.455 volts RMS, so I sort of expect it, but I don't really know what I'm fighting. At 10 LED's, (R1=12.575K) we fall to 573.36mW / 714.17mW = 80.28 % Efficiency.
Finally, here's an updated LTSpice file (*.asc) to go along with the above picture:
Version 4
SHEET 1 1364 680
WIRE 64 -32 64 -64
WIRE -240 0 -272 0
WIRE -224 0 -240 0
WIRE -272 64 -272 0
WIRE 272 64 256 64
WIRE 288 64 272 64
WIRE 64 80 64 48
WIRE 112 80 64 80
WIRE 224 80 176 80
WIRE 256 80 256 64
WIRE 256 80 224 80
WIRE 304 80 256 80
WIRE 400 80 368 80
WIRE 496 80 464 80
WIRE 592 80 560 80
WIRE 688 80 656 80
WIRE 784 80 752 80
WIRE 928 80 848 80
WIRE 64 112 64 80
WIRE 0 160 -160 160
WIRE 224 160 224 80
WIRE 64 240 64 208
WIRE 224 240 64 240
WIRE 928 240 928 80
WIRE 928 240 224 240
FLAG -272 256 0
FLAG 272 64 D1
FLAG -240 0 V1
SYMATTR InstName L2
SYMATTR Value 220µH
SYMATTR Type ind
SYMATTR InstName L1
SYMATTR Value 220µH
SYMATTR Type ind
WINDOW 3 -7 54 Left 2
SYMATTR Value 6.2
SYMATTR InstName V1
SYMBOL npn 0 112 R0
SYMATTR InstName Q1
SYMATTR InstName R1
SYMATTR Value 13.336K
SYMATTR InstName D1
SYMATTR Type diode
SYMATTR InstName C4
SYMATTR Value 22nF
SYMATTR InstName D2
SYMATTR InstName D3
SYMATTR InstName D4
SYMBOL LED 688 64 M90
SYMATTR InstName D5
SYMBOL LED 784 64 M90
SYMATTR InstName D6
TEXT -256 224 Left 2 !.tran 0 4.2ms 0.2ms startup
TEXT -824 -40 Left 2 ;FOR 3 LED's, (D1-D3 and R1=15.000K)\n613.12mW / 714.21mW = 85.85 % Efficiency\n \nFOR 4 LED's, (D1-D4 and R1=14.135K)\n613.98mW / 714.19mW = 85.97 % Efficiency\n \nFOR 5 LED's, (D1-D5 and R1=13.410K)\n607.05mW / 714.26mW = 84.99 % Efficiency\n \nFOR 6 LED's, (D1-D6 and R1=13.336K)\n594.96mW / 714.17mW = 83.31 % Efficiency
TEXT -240 256 Left 2 ;For each case, R1 has been adjusted to draw in the same amount of power at V1 (714mW).\nEfficiency = V(D1)*I(D1) / V(V1)*I(V1) electronics-stackexchange-efficient-6v-joule-thief-query-1
TEXT 104 -72 Left 2 ;L1-L2 is a hypothetical perfect coupled inductor\n(ESR=1mOhm, 100% coupling).\nD1=65.975mA RMS, 37.424mA AVG, 172mA PK for 4 LED's.\nD99 & C4 prevent negative currents in diode string.
Thanks ahead of time to all who can shed light on a truth that seems to be "increased voltage means increased efficiency" and more importantly, WHY this seems to be true, and also what "brick wall" it seems to hit.
