Thanks to The Photon < I posted the wrong connector, but you are in luck. this one works as an edge insert to thick boards 0-18GHz $6(1) 116mil depth
Best bet for 3GHz for cost and high performance if it can be made to suit application.
Maximum VSWR is 1.20 (~21dB) at 11GHz Molex £1.37(1) Farnell
Molex 0733910060 $3 (1) 18GHz
When you find an RF connector with no VSWR or Return Loss specifications, be very concerned.
Consider machine and plating tolerances and the precision of the feed pin , how its soldered and any variations. These all significantly affect Return loss at 1GHz and much more at 10GHz etc...
Then decide if 10 dB RL is adequate for a cheap connector.
You ought to expect this in cheap mass-produced RF connectors without quality controls. Would rather pay extra for 30dB .. You can't afford 40dB or even need it because the geometric tolerances are < 100ppm and dielectric tolerances for d constant, also very tight.
Since you asked about 100 mil boards, I assume rigidity is important to you.
In this case consider adding rigid substrate or other stiffener mechanics.
From my experience, SMD connectors are just bad news mechanically for any type with forces applied to the cable and jack.
But I understand if you have a height restriction or packaging problem.
There are alternatives. yours on left, on right Amphenol p.n. 901-10511-3
$2.50 left , $13 right
Edge connectors take a lot of abuse and SMA connectors MUST be careful torqued by a calibration tool for optimal performance.
$25 (1)
02K249-40ML5 Rosenberger $105 (1)
My experience came from setting up Iridium Satphone LNA testset for mobile radio chips with Anritsu VNA calibrated to 0.1dB accuracy and 0.01dB resolution and working with Motorola, until they decided to decommission 1st system from lack of sales.
for kicks 110GHz rated >$1k
