I have a board which I want to place in a panel. I can do it with Place -> Embedded Board Array/Panelize. Easy!
After that I was intended to place additional wiring and connectors on the panel (outside the multiplied boards). This wiring tracks should brake when the boards goes off the panel.
This is what I have in 3D view for now:
As you can see - the tracks should go outside the board edge. The narrower tracks on the bottom are what I tried to draw on the panel But I had to aim blindly! Look what I have in 2D:
As you can see - no tracks at all! It looks like the boards on the panel is not a board anymore - it is a kind of uneditable object.
In the Altium's documentation:
but it is not advisable to place any other objects that would represent the actual physical design
Taken from this page: Embedded Board Array
So it looks like I'm trying to use the tool in the way it is not intended to be used at all.
It's time for QUESTIONS:
  1. Am I able to see tracks in 2D view of the panel?
  2. Is there any tools in Altium to do this out-of-the-board wiring in a way to reduce human error probability (whis is high if I'd place tracks in PCB without a schematic representations and without DRC control)?
  3. What will happen with the tracks after the FR4 bridge under them would break? Probably I should place V-grove on the opposite side of the panel, should I?
  • \$\begingroup\$ Use a Gerber viewer on the final Gerber output. \$\endgroup\$ – Brian Drummond Mar 21 '18 at 20:57
  • \$\begingroup\$ @brian, how can this help? \$\endgroup\$ – Roman Matveev Mar 21 '18 at 21:03
  • \$\begingroup\$ A Gerber viewer will show whether the tracks are on the information you're going to make the boards from. \$\endgroup\$ – Brian Drummond Mar 21 '18 at 21:04
  • \$\begingroup\$ I agree with @Brian. Also consider putting wide traces, or smt pads on your PCB, so your aim on the panel won't need to be super precise. Disclaimer: I have not tried this... Let us know how it turns out. \$\endgroup\$ – Chris Knudsen Mar 21 '18 at 21:14
    \$\begingroup\$ Aussie bloke Dave Jones has a video in which he talks aboot it. Worth watching. They may have changed the way the panel behaves though- I don't usually fiddle with the generated panel, only add tooling holes and such like. \$\endgroup\$ – Spehro Pefhany Mar 22 '18 at 9:52
