I am using the newly-made-free Atollic TrueSTUDIO for STM 32 and built a CMSIS-based STM32F3 project from scratch.
When I try to build the project, I get the following Build Console error:
arm-atollic-eabi-objcopy: 'ProjectName': No such file
and
arm-atollic-eabi-size: 'ProjectName': No such file
I'm not even sure if the project built itself correctly, although the CDT Build Console seems to suggest that it was built. For instance, if I try to create a new Debug configuration, there is no .elf file. For reference, here is the entire console output:
Info: Internal Builder is used for build
C:\Program Files (x86)\Atollic\TrueSTUDIO for STM32 9.0.0\ide\jre\bin\java -jar C:\Program Files (x86)\Atollic\TrueSTUDIO for STM32 9.0.0\Tools\arm-atollic-reports.jar convert hex sizeinfo list ProjectName
Generate build reports...
Converting build output to hex
Output sent to: ProjectName.hex
Converting build output to hex done
Print size information
Print size information done
Generate listing file
Output sent to: ProjectName.list
Generate listing file done
Generate build reports done
10:47:58 Build Finished (took 353ms)
This error happens if build artifact is not selected.
Project Properties -> C/C++ Build -> Settings -> Build Artifact
Build Artifact 1
Need to set artifact type to Executable, error is changed:
Info: Nothing to build for ProjectName
It happens, because artifact extension is also required. Need to set elf there.
Build Artifact 2
