The stator magnetic flux can be visualized and mathematically described as two flux waves rotating in opposite directions. Because of the shape of the torque vs. speed curves and the effects of the rotor magnetic flux, once a direction of motion has been established, the forward torque is higher than the reverse torque as shown below. The solid line is the sum of the forward and reverse torques.
The above illustration is taken from Fitzgerald, Kingsley Umans, Electric Machinery 4th ed and the paragraph above is a summary of a 1-1/2 page explanation in that text. Also in that text, reference is made to another text for "an extensive treatment of fractional-horsepower motors."
Forward vs. Reverse Torque
The torque produced by the forward-rotating magnetic fields is higher than for the reverse because of the shape of the curves. The torque vs. speed characteristics can be determined by analyzing the equivalent circuit of the motor. That circuit for a single phase motor that has been started is shown below. A more complex version of the circuit may be required for an accurate determination of the characteristics.
Split Phase Starting and Running
A single-phase motor has two stator windings with different resistances and inductances or with a series capacitor in series with one of them. Split-phase motors have a phase displacement between the currents main and auxiliary windings. That creates an approximation of a two-phase motor. An analysis of a split-phase motor still makes use of the theory of two revolving fields. Another concept that is used is the symmetrical-component concept. Each of the two concepts has advantages and disadvantages.
