I am using a 16-bit, 16Mhz ATmega328P microcontroller. I have set the output of the timer to toggle mode. Hence generating a square wave.
my question is, do I still get a maximum of (2^16-1) 65535 when the 16MHz clock has been prescaled by 8 (2MHz)?
I want to know so that I can work out the duty cycle, as the value of OC1A changes.
Thanks!
Yes, it will just take 8x as long to get there.
  • \$\begingroup\$ Could you explain what the Max frequency would be? I know that when 0 is reached, the output is toggled high or low. thus is would only be half the time period \$\endgroup\$ Mar 22 '18 at 22:56
  • \$\begingroup\$ Overflow frequency: \$\frac{f_\mathrm{scaled}}{2^{16}}=\$ 30.5 Hz, which is double the frequency (as you said). So, if you use the full depth of the timer (just letting it run from zero every time) at 2 MHz, your frequency will be ~15 Hz. \$\endgroup\$
    – awjlogan
    Mar 23 '18 at 10:09
