I am using this isolated DC-DC converter as a power supply to ensure regulated 12.0V: Traco Power TEN60-1212N.
In the application notes, the following EMI filter is suggested: enter image description here with L1 = 3.3µH, C1,C4 = 6.8µF / 50v and C6,C7 = 1000pF / 2kV and C2,C3,C5 = NC.
In my application, I still have common ground (so it's not fully isolated, I just need the 12.0V): enter image description here My questions is about C6 and C7: What effect do these capacitors have?
In my circuit, C7 will naturally not be relevant.
(Context: The power supply provides a stable 12V under battery operation in an automotive setting, where the battery voltage can be very noisy and dip low when the starter operates. The output is used for the ignition coil and injection nozzle.)
Assumptions:
You understand what the proposal meant by
"Recommended external EMI filter for EN55022 class A:"
enter image description here the spec enter image description here A good PSU with similar proposed filter installed
Imagine this to be 20~30 dB higher in the UHF band if not installed unless shielded in an enclosed like a proper Faraday Shield.
It means this proposal is necessary to meet many user applications to get below the Class A Industrial threshold for unintended radiations. Class B Consumer level is 10 dB harder. (lower)
  • neglecting C7 since you have this shorted out with a common ground (assuming it is a square low inductance connection )
    • What does C6 do?
C6 bypasses the radiation of noise in the PSU in the unit acting as an unintended radiator. By careful low impedance ground planes under the part it shunts the RF that is radiating like an antenna between input and output. enter image description here enter image description here
An example of 1nF 100V 1812 MLCC for C6 180x120 mil (4.5x3mm) (not to scale 8-} but shown for dramatic reduction in UHF unwanted emanations of common mode and differential input output noise.
A 1nF has no effect below 10MHz and very little below 100MHz but "may have" (depending on s-parameters) low Z above this f to radiated noise if the load is 2.5 Ohms on the output.
So the transient switch noise internal to the regulator can radiate due to ~1~2ns rise times of some switches. (assumption and presumably why they propose this)
So C6 attenuates with the L1 (rising X(f) on input and Load Caps on the output. Output caps help to attenuate load regulated and source regulated noise but not the differential noise between input and output from the regulator itself. This is a common proposed filter and relies on your microwave circuit layout experience to include a spot for this during testing with ground planes around it and 1kV insulation rules applied to IN-OUT gaps.
In this case C6 is redundant, as the series combination of the caps on the output with the caps on the input (which share a common ground) creates capacitance much larger than C6.
Juts make sure at least one cap is close to the converter on each side, and the common ground between them is a plane and not a tiny trace.
