you can use isolated dc-dc converter for driving the high-side mosfet.
Here is the link for isolated dc-dc converter:
https://www.mouser.in/ProductDetail/Murata-Power-Solutions/CRE1S1212SC?qs=pFP7BvE1Pmz5XALT59wZHw%3D%3D
isolated dc-dc converter will give you isolated VCC and GND .
To turn on the mosfet a gate voltage above threshold voltage is required with respect to source terminal.
FUNCTION OF DC-DC CONVERTER:
consider that the required voltage to turn on the mosfet with respect to source is 12V.
If the source already has 10v(floating),then we have to supply 10+12 =22V to the gate in-order to turn on the mosfet. So DC-DC converter will lift up/adjust the "vcc" according to the GND in the output side.And this supply is given to the driver ic/optocoupler . So output pwm will be swithing with this vcc and ground.
