I'm trying to implement one digit counter from 0 to 9 using an FPGA board. The digit is incremented when the signal "pulse" is set. The "pulse" signal is set every fixed number N of clock cycles. The clock frequency is 5 MHz. However the counter jumps inconsistently depending on the "pulse" period. For example when it's set to 1000000, the counter works fine and the digit is incremented every 1/5 of a second. When the period is different, it does not behave as expected. Even if the period is set longer, every 5000000 clock cycles, it jumps from 0 to 1 to 0..., the increment is 10!
Here's the VHDL code that increments the counter based on the pulse.
process(clk, reset)
begin
    if (reset = '1') then
        digit_reg <= (others => '0');
    elsif rising_edge(clk) then
        digit_reg <= next_digit;
    end if;
end process;
process(pulse, digit_reg)
begin
    if (pulse = '1') then
        if (digit_reg >= 9) then
            next_digit <= (others => '0');
        else
            next_digit <= digit_reg + 1;
        end if;
    end if;
end process;
Any idea what the problem might be?
Thanks.
  • \$\begingroup\$ You mean when you simulated it ? \$\endgroup\$
    – Mitu Raj
    Mar 24, 2018 at 17:41
    \$\begingroup\$ Are you sure pulse is high for only one clock cycle? If not you need to make sure of that. \$\endgroup\$
    – C_Elegans
    Mar 24, 2018 at 17:42
  • \$\begingroup\$ No, when synthesized. \$\endgroup\$
    – Joseph
    \$\begingroup\$ First your next_digit is a latch. It gets set if pulse='1' but otherwise you haven not given it a value. I have no idea where 'pulse' comes from. Is it generated of the same clock? I think we need to see more code from that. \$\endgroup\$
    – Oldfart
    Mar 24, 2018 at 17:43
    \$\begingroup\$ remove digit_reg from the sensitivity list and check. \$\endgroup\$
    – Mitu Raj
    Mar 24, 2018 at 18:02
Add an else branch to fix the broken combinatoric process description:
begin
        else
        end if;
    else
        next_digit <= digit_reg;
    end if;
end process;
Your implementation will not fit good to any existing FPGA hardware because it uses an asynchronous and synchronous reset.
This is how to describe a fully synchronous counter modulo 9 with synchronous reset and clock enable (pulse):
process(clk)
begin
        if ((reset = '1') or (digit_reg >= 9)) then
        elsif (pulse = '1') then
            digit_reg <= digit_reg + 1;
        end if;
    end if;
end process;
    \$\begingroup\$ You have completely misread the question. The OP is not trying to implement a mod-9 counter on "clk". He wants to count using the generated clock pulse. \$\endgroup\$
    – Mitu Raj
    Mar 24, 2018 at 18:47
  • \$\begingroup\$ Actually the counter rotates after 9 it restarts from 0, hence a mod-9 counter. Sorry for not clarifying this in the OP. \$\endgroup\$
    – Joseph
    Mar 24, 2018 at 18:51
    \$\begingroup\$ @joseph Seems like your question itself is misleading. If you are trying to implement a mod 9 counter on clk ( I thought pulse ) this is the correct solution indeed. Then why do you even describe like your functionality was met when it incremented every 1/5 seconds, at first place. \$\endgroup\$
    – Mitu Raj
    Mar 24, 2018 at 18:59
    \$\begingroup\$ OP never clarifies whether pulse is a generated clock of 5x10^6 clk cycles or a pulse of "clk period" that occurs every 1/5 seconds. I answered thinking the first way and you answered thinking the latter way \$\endgroup\$
    – Mitu Raj
    Mar 25, 2018 at 0:26
    \$\begingroup\$ "You still haven't understood how VHDL works and how VHDL or any other HDL is translated to hardware " -- misleading question created your misconceptions. I don't claim to be pro expert with 25+ industrial experience but knows enough to help people out here. \$\endgroup\$
    – Mitu Raj
    Mar 25, 2018 at 0:32
