I'm building an LED lamp and I want it to have no ON/OFF switches/buttons sticking out from the lamp. The switch function I would like to have is like a pushbutton: You push it and it pops out and then you can turn it as a potentiometer and then push it back in.
I have seen the kind of switch I'm describing, but I don't know how it's called. One example where this kind of swich is used is in Opel Astra radio panel. Opel astra radio panel
Any ideas how is this switch/button called?
An image search for "push-lock potentiometer" will get you half-way there. You'll need to refine it with the on-off switch but I suspect that will make the search results rather less useful.
Note that '-' on most web searches will exclude that term.
it is a latching push button switch
