[I am interested specifically in the case of state of-the-art consumer processors and motherboards]
To clarify what the setup might be in practice, imagine wires running vertically between each pair of contacts on the CPU and socket.
I don't have much expertise in this area, but these are the potential issues I am concerned about:
- The additional length of the conduction path from the processor slows down the speed of processing.
- The change in length of the conduction path means that the processor won't work at all as the devices are designed to operate with a specific length of conduction path.
- There is interference of some sort between the conductors running from the CPU to the socket.
In each case I am wondering if this is a problem and, if possible, what sort of effects would be observed.
