12
I'm relatively new to electronics, and have no formal training other that what I picked up through my electrical engineer father. I solder well, can read schematics, have assembled kit projects with a rough understanding of how all the parts work, and know basic electrical terminology and principles. Ohm's law is about as far as my electical math skills go.
So while this may seem like a very basic question to a more experienced and better trained person, please bear with me.
I spent a couple weeks messing around with some LEDs. I started by just hooking one up to my power source. Then, what happens when I add a resistor? What about a capacitor? what about resistors in parallel vs. series? From just playing with my breadboard, I now have an LED that blikcs randomly. Impressive? Nah...but I figured it out myself, and feel that I truly understand it.
Now, I want to design a synthesizer from scratch to give myself an understanding of how specific components affect sound. Starting from the most barebones circuit that can make a noise, I want to add a pot, then some capacitors, then some 555s...you get the idea. I just want to start with the basics and play around to see what happens.
Finding that circuit is proving to be quite difficult. I'm looking for a circuit more complex than hooking a speaker directly to a battery but less complex than http://www.musicfromouterspace.com 's Wacky Sound Generator (which, while simple compared to a real synth is still a lot more complex for me to truly understand what component A vs. compoent B does).
In essence, I want to find the sonic equivalent of Battery-to-Speaker and start playing with what can happen in between.
Electronics golf: what can produce sound with the minimal number of components?
  • 6
    \$\begingroup\$ Well, a switch makes a snapping sound when you flip it. No batteries required :) \$\endgroup\$
    – gbarry
    Jul 24, 2012 at 19:51
    \$\begingroup\$ Yeah, but the snapping sound doesn't get louder when I add a pot. :) \$\endgroup\$
    – dwwilson66
    Jul 24, 2012 at 19:55
  • \$\begingroup\$ You double the number of components required, if you add a pot :) \$\endgroup\$
    – gbarry
    Jul 24, 2012 at 19:58
  • \$\begingroup\$ D'oh! stupid complexity. \$\endgroup\$
    – dwwilson66
    Jul 25, 2012 at 12:21
  • \$\begingroup\$ I swear I can hear those old fluorescent ballasts (just an inductor) hum to the tune of 50/60Hz (depending on your national transmission scheme). ;-) \$\endgroup\$
    – shimofuri
    Jul 25, 2012 at 16:33
5 Answers 5
10
The 555 is a good way to start making tones in a speaker. I suggest you make a simple oscillator using one, before you attack projects that use several of them.
Also, we had a question, What is the simplest way to make an oscillating signal? That turned out to be an inverter gate with feedback.
  • \$\begingroup\$ thanks for the excellent link. talk about missing the forst for the trees, I've been so hung up on sound that I forgot to search "oscillator". Oy. \$\endgroup\$
    – dwwilson66
    Jul 25, 2012 at 12:25
    \$\begingroup\$ Solutions provided in the linked question are square-wave oscillators. Sound can be produced by an oscillating signal regardless of the wave characteristic - a sinusoidal wave though will produce a more natural sound. Simple and dirty: Hartley Oscillator and the Colpitts Oscillator (with Clapp Oscillator variant). Go Google/Wikipedia. \$\endgroup\$
    – shimofuri
    Jul 25, 2012 at 20:41
9
Super-simple solution: a Schmitt's trigger inverter like this:
and you create a simple square wave tone. You can also filter and manipulate it to make different waveforms.
Consider that with oscillators at different frequencies you can create virtually every sound: that's what the Hammond organ does.
A slightly more complicated but extremely more versatile solution is to use a microcontroller with a quick DAC and generate tones with it. Then you can do many things, from using pots to set frequency and volume, but also create loops or more sophisticated things.
  • \$\begingroup\$ Thanks! Another great place to start along with a 555. I'm hoping to work up to a microcontroller eventually; I've got some ideas for arduino-controlled sonic environments. But...before I get there, I really want to start with something like the above and see what happens (sonically & on a scope) by swapping out different resistors, adding & taking away caps, etc... I tend to learn best by experimenting and making my own "Oh, so that's what THAT does" discoveries. \$\endgroup\$
    – dwwilson66
    Jul 26, 2012 at 13:29
8
Sound is just vibrations, vibrations are caused by "blinking" the speaker coil. The only difference is instead of blinking a few times a second, to blink a few hundred times a second. Whatever you did to make the LED blink, change out some capacitors with smaller ones, and stick the speaker in place of the LED. It might make noise.
    \$\begingroup\$ I tried...it didn't. :( That being said, the smallest cap on hand was 1uf. I've got an assortment of pf caps on order this week, all the way down to .001pf, I think...so I'll keep trying smaller caps to see what happens. Thanks! \$\endgroup\$
    – dwwilson66
    Jul 24, 2012 at 19:54
  • \$\begingroup\$ @dwwilson66 one thing to keep in mind is that the speaker may be too "large" for such small power circuits to have any effect (audible) on it. A tiny low-power piezo buzzer might be a good starting point, not an actual magnetic-driver speaker \$\endgroup\$
    – KyranF
    Aug 17, 2016 at 21:39
If you want something where you can easily change the sound, I recommend the Atari Punk synthesizer, as published in Radio Shack's Engineer's Notebook, by Forrest Mims. enter image description here
It certainly wouldn't qualify as "simplest", but it is the simplest circuit that can produce something approaching music. It's also a 1-IC circuit if you use the dual timer 556 package, instead of two 555's.
The simplest circuit, assuming it can be manually operated, can be just a battery and speaker with wire brush at one end. By short circuiting, by grinding the brush against other electrode, you will create audible noise.
    \$\begingroup\$ Even simpler: Any circuit you like, dropped from a tall building onto concrete. \$\endgroup\$
    – The Photon
    Aug 17, 2016 at 21:51
  • \$\begingroup\$ ok, i must admit you beat me \$\endgroup\$ Aug 20, 2016 at 12:49
