I am developing a UART protocol based on ASCII encoding. Communication is between a PC and an STM32 board. Packet format is like this: Packet: {STX,DATA,ETX} Where STX and ETX are 0x02 and Ox03 in ASCII.
Example:
STXHELLOETX in Hex would be: 0x02 0x48 0x45 0x4c 0x4c 0x4f 0x03
My question is where exactly is the position of \0 character in my packet? is it after ETX like this: STXHELLOETX\0 or after HELLO like this: STXHELLO\0ETX ?
  • 8
    \$\begingroup\$ It's your protocol, you get to choose. Do you even need the \0 if you end always with ETX? \$\endgroup\$
    – Colin
    Commented Mar 26, 2018 at 14:24
  • \$\begingroup\$ Nulls are rarely used in line protocols, in effect ETX is filling the role in your protocol that a null serves when a program internally stores a null-terminated string. Packet buffers usually track length, rather than using a terminating null, but even if they use a terminating null it is removed on sending and added on receiving. \$\endgroup\$ Commented Mar 26, 2018 at 17:07
7
You specify your packet format as {STX,DATA,ETX}.
The entire DATA content of the packet is contained within the DATA field, between the STX and ETX.
If you decide to send NUL-terminated strings in your packets then the NUL is part of the string - part of your DATA field.
So you would send: STXHELLO\0ETX
  • 4
    \$\begingroup\$ I would say that the NUL terminator of a C string is a feature of the C language and should not be considered as part of the string. The actual string to be sent would just be the characters up to, but not including, the NUL. \$\endgroup\$ Commented Mar 26, 2018 at 16:51
    \$\begingroup\$ Indeed, this response is very incorrect, and appears to have confused the asker into mistakenly accepting it. The format originally described simply does not send a null, and indeed most line protocols do not use nulls. If at some point a packet with or without the framing STX/ETX is stored inside a computer in a null terminated C string rather than in a length-designated buffer, then a null would be added. But it's not necessarily the case that this will happen at all. Typically you would only see null-terminated strings when constructing or deconstructing packet fields. \$\endgroup\$ Commented Mar 26, 2018 at 17:02
  • \$\begingroup\$ @PeterBennett, OPs question states "I am developing a UART protocol". It's OPs choice how strings are sent, as others note. \$\endgroup\$
    – TonyM
    Commented Mar 26, 2018 at 17:44
it depends on the DATA (the 'HELLO' word in your example):
--if it's a null-terminated string (a C-string), in wich a string is represented by an array of chars ended by a null character '\0',
or:
--if it's a 'normal' array of characters.
so the packet can be:
--STXHELLO\0ETX for the null-terminated char array: [0x02 0x48 0x45 0x4c 0x4c 0x4f 0x00 0x03]
or:
--STXHELLOETX for the normal char array: [0x02 0x48 0x45 0x4c 0x4c 0x4f 0x03]
or:
--the null char can be anywhere in the packet!...it's your protocol, as colin-s commented;
  • \$\begingroup\$ While this includes the overwhelmingly usual possibility, you've buried it in the middle, and failed to really explain why that is the usual. \$\endgroup\$ Commented Mar 26, 2018 at 17:09
    \$\begingroup\$ @chris-stratton: i haven't any intention to 'explain why that is the usual' possibility... i only mentionned 'some' possibilities since the question is a bit general... \$\endgroup\$
    – moyoumos
    Commented Mar 26, 2018 at 17:26
