I'm working with these two MOSFET CSD18504Q5A and CSD18510Q5B. With Altium I need to design their PCB footprint, but their datasheets in the section "Recommended PCB footprint" for each dimension they provide a minimum and a maximum. How can I draw the footprint using max and min? Which are the design criterias?
  • \$\begingroup\$ Use whatever lies inside these values and works with all your other design constraints too \$\endgroup\$
    – PlasmaHH
    Commented Mar 26, 2018 at 16:01
Here's the recommended layout for your first part: enter image description here
The two values for each dimension are not minimum and maximum, they are metric and "customary" units (inches).
Use the metric values if you are designing in metric, and the inch values if you are designing in inches.
