I'm not an electrical engineer, so please forgive my lack of technical terminology. I'm researching an idea that requires me to create a PCB that will have a camera module record video and store it to a microsd card. I'd like it to be able to record for 8-12 hours. How can I calculate what battery will get the job done, given a specific camera module and microcontroller?
What is the smallest battery that I could use to accomplish this, you think?
  • \$\begingroup\$ Besides the battery have you considered the memory requirement for 8-12 hours of video? It depends on your frame rate and resolution, but you will probably not be able to store all your data on a single microsd card. \$\endgroup\$ – Barry Mar 27 '18 at 2:30
To answer the question you need to determine for yourself what kind of camera you are going to use, what kind of video resolution to have, frames per second, and what kind of MCU can handle this data stream and put it on a uSD card.
As a ballpark example, take available options: Raspberry Pi ZERO, and camera module V1. You will probably need a highest capacity uSD card, video class. For a 720P H.264 video you will need about 64 GB for 10 hours of recording.
According to some sources in Raspberry community, a camera and MCU might consume about 200 mA in continuous 720p mode. A SD card might take anything between 50 mA to 100 mA on writes, see this info.
So, the target consumption is likely to be about 300 mA. This is substantial.
Now, 300 mA for 10 hours (at 3.7V Li-ION cell) will land you with one high-quality 18650 cell with 3000 mAh capacity, approximately speaking.
| improve this answer | |
The battery required would depend on the current consumption. A rough estimate would just be multiplying your time (8 hrs.) with the total expected maximum current consumption of all your active PCB components to determine the required mAh (milliamp-hour) rating of the battery.
(Some more info that could help determine battery life: Does mAh measure how long a battery would last?)
