I am amidst writing up calculations for electronics research, but am unsure how to calculate the time delay for the sum output. I am needing to calculate the time-delay for the sum and carry outputs of 1-bit(genus=2) and 2-bit(genus=4) ripple-carry adders. The 1-bit adder has 2 XOR gates, 2 AND gates, and 1 OR gate. The 2-bit adder 4 XOR gates, 4 AND gates, 2 OR gate.
closed as too broad by Eugene Sh., Finbarr, Voltage Spike, Michel Keijzers, RoyC Mar 28 '18 at 8:36
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ Sum up times on a critical path. \$\endgroup\$ – Eugene Sh. Mar 27 '18 at 15:31
For a 4-bit ripple carry adder, since the carry is rippled through, the final Cout and S3 is valid only after the propagation delays through each full adder. So the total delay would be: $$t_D = 4 \times t_{FA}$$
Inside Full Adder:
The critical or most delayed path is for C_out. It is via XOR --> AND --> OR. Suppose all gates have equal delay = \$t_g\$, then \$t_{FA} = 3t_g\$. Therefore \$t_D = 12 t_g \$
