I have a more specific question than this one. As I understand it, different 1.5 V batteries are distinguished by "capacity" (AAA < AA < C < D), measured in mAh (milliamp-hours(?), which is actually what I think I would call charge, 1 mAh = 3.6 C). But what current can be supplied by these batteries (i.e. at what rate can the "capacity" be drawn?)
I would like to replace 6 C batteries with a 9v DC power supply but need to know what maximum current rating is appropriate.
  • \$\begingroup\$ The appropriate maximum current rating is determined by the device you are powering, not the batteries you're replacing. electronics.stackexchange.com/questions/34745/… \$\endgroup\$
    – Asmyldof
    Commented Mar 28, 2018 at 7:48
  • \$\begingroup\$ You can't easily say how much current a battery can deliver according to its size. It depends a lot of the battery technology. But the 9VDC blocks are normally really bad in providing high currents. \$\endgroup\$
    – Botnic
    \$\begingroup\$ About 2 A max. If you know the load, you might get away with less. \$\endgroup\$
    – winny
    Commented Mar 28, 2018 at 8:08
    \$\begingroup\$ I wou;dn't expect more than 5A from a 1.5V C battery, probably closer to 50mA it depends. \$\endgroup\$ Commented Mar 28, 2018 at 8:24
    \$\begingroup\$ How long did the 6 C batteries last? You should be able to get a finger in the air guess for current draw from that. professional.duracell.com/downloads/datasheets/product/… this datasheet shows curves for different current draws for a specific duracell battery. \$\endgroup\$
    – Colin
    Commented Mar 28, 2018 at 8:30
You need to know the current requirement for the CD player to work correctly. Use a digital multimeter (DMM) to measure the current that is drawn by the device from a fresh set of six C cells. Make sure that the CD player is running with the disk motor active and the sound level turned up to maximum.
You could also use a bench power supply that is set to a nominal 9V and use test leads to clip that supply into CD player at the end contacts of the six cell battery compartment and connected to the DMM in current measurement mode. When using this method make sure to use a bench supply that is obviously capable of delivering all the current that the CD player would need (in other words a 3A to 4A supply and not some whimpy little 9V wall wart rated at 200mA).
Once you have the current measurement I would multiply it by 1.5 for reserve capacity and you will have an appropriate selection for a 9V power supply at that current level of capability.
This depends on the actual battery model you are using and it is hidden in its datasheet (yes, batteries have datasheets too!).
Take for example a Duracell industrial C cell.
In the datasheet you'll see several graphics showing the cell performance for different load conditions. The most common conditions are when the cell is discharged with a constant current rate or with a constant power rate (constant resistance rate was more important when batteries where used to power simple resistive loads, e.g. an incandescence light bulb in an flashlight).
What does the manufacturer guarantees you? Look at the constant current load graph with higher current values:
The maximum current at which the manufacturer characterized the cell is 2000mA, i.e 2A. This is the best guarantee you can get for that cell: it will be able to source 2A max.
Since the voltage keeps dropping during discharge, note that the actual useful capacity depends on what you consider the so-called cut-off voltage, i.e. the voltage at which the load stops working (or working reliably).
In the modified graph below I give two examples of what you can consider the "useful capacity" of the cell, given two different choices of cut-off voltage.
To answer your question more directly, as others have focused on what the load actually needs, the current rating of an "equivalent" power supply (i.e. a supply that can replace those C cells whatever their load may be) is at least 2A because that is the maximum current the manufacturer guarantees it can be drawn from those model of cell.
Of course that maximum, as I hinted before, depends on the actual model of the batteries and, more importantly, on their chemistry. The maximum current won't be much different for different manufacturers as long as the chemistry is the same (alkaline, NiCd, NiMH, etc.). Apply a safety margin of 50% (for truly paranoid designers) to take into account the spread across different manufacturers and you get a 3A rating for your "equivalent power supply" for any alkaline C cell on the market.
