-5
I have 6Amp socket all around my home, but my washing machine has 16Amp plug. Can convertor be used to plug 16 Amp in 6 amp socket somehow? I am in India, so electricity is 240v50Hz
closed as off-topic by Marcus Müller, Dave Tweed Mar 29 '18 at 17:21
This question appears to be off-topic. The users who voted to close gave this specific reason:
  • "Questions on the use of electronic devices are off-topic as this site is intended specifically for questions on electronics design." – Marcus Müller, Dave Tweed
If this question can be reworded to fit the rules in the help center, please edit the question.
The whole sense of having plugs with lower rating is that you shouldn't attach larger loads to that plug or circuit.
So, no.
  • \$\begingroup\$ so there so device like transformer convert low to high voltage kinda stuff \$\endgroup\$ – murmansk Mar 29 '18 at 17:03
    \$\begingroup\$ What's unclear about "no"? \$\endgroup\$ – Marcus Müller Mar 29 '18 at 17:03
  • \$\begingroup\$ It's not a matter of voltage @murmansk. It's more about how much current will be drawn. \$\endgroup\$ – KingDuken Mar 29 '18 at 17:29
  • \$\begingroup\$ @KingDuken device has rated current as 0.6 amp, so i am thinking 16Amp to 6 amp plug convertor might work \$\endgroup\$ – murmansk Mar 30 '18 at 18:20
  • \$\begingroup\$ I'm almost certain it doesn't draw 0.6 A. That would only be 144 W, not enough to make hot water in acceptable time. \$\endgroup\$ – Marcus Müller Mar 30 '18 at 19:05
Can I power a 16 A load on a 6 A socket?
No.
Your sockets are rated to carry 6 A safely. If you connect a 16 A load they will overheat and risk fire.
Can I run the washing machine on a 6 A socket?
Yes if the washing machine draws less than 6 A. at 240 V this would be a maximum power of 240 x 6 = 1440 W. You will find this information on the rating plate.
