I'm playing with an MCU board (like Arudino) to read the state of several switches in my home (i.e. magnetic switches). The wires between the sensor and the board are quite long: 15+ meters in a star topology.
I would isolate the inputs from the MCU, using opto-couplers. To provide the voltage needed to turn on the diode I'm going to use an isolated DCDC converter.
Question: do I need to use a different DCDC for each input? Or may I live with only one? In this case I will end up with all sensors that share the same power supply rail.
I.e.: one side of the switch goes to +12V (shared across ALL switches) while the other sides go to the anodes of the opto-couplers.
It's not an industrial design: I'm fine if it works without false detections due to the environmental noises.
EDIT
To be more clear. Two ways:
A
or B
  • \$\begingroup\$ Your setup is unclear, or maybe I'm just sleep deprived. Still, add some clarification details and review grammar. \$\endgroup\$
    – A.S.
    Commented Mar 29, 2018 at 18:38
  • \$\begingroup\$ I'm sorry for my awful English. What details should I add? \$\endgroup\$
    – Mark
    Commented Mar 29, 2018 at 18:40
You should be fine having the shared power rail(case B), although I'm not sure how many switches you could be dealing with, so you might want to calculate the max current draw with all of the switches closed, which would be:
Current through one switch: (12-Diode_voltage)/680
Current through them all: Number_of_Switches * Current_Through_One_Switch
So long as the DC-DC converter can put out enough current (which is likely, unless you're going to have 100s of switches) it'll be fine.
  • \$\begingroup\$ Got it, thank you. Current is not a deal here - I'm going to have 4-5 sensors. \$\endgroup\$
    – Mark
    Commented Mar 29, 2018 at 18:58
  • \$\begingroup\$ If you're happy with the answer, could you mark it as accepted? Thanks :) \$\endgroup\$ Commented Mar 30, 2018 at 20:28
  • \$\begingroup\$ I was waiting for any other answer. Don't worry. I give you some points. \$\endgroup\$
    – Mark
    Commented Apr 2, 2018 at 11:19
