I am using the STM32L471RG trying to put the mcu in standby mode and then wake it up on a timer using the RTC. The mcu appears to be going to sleep, but I have been monitoring the power consumption and it is remaining higher than it should be (~3mA) compared to the expected <1uA. Also, the MCU is not waking up from the timer after entering the __WFI() function. I tried replacing the __WFI() function with a while loop that just checks the RTC_ISR_WUTF flag, and the flag is being raised, it just isn't triggering the __WFI(). Here's the code I've been using. It was taken from example code on the ST website. The code was written for the STM32L476RG and we are using the STM32L471RG, so this could possibly be the reason it is not working. Any thoughts?
  * @file    Examples_LL/RTC/RTC_ExitStandbyWithWakeUpTimer/Src/main.c
  * @author  MCD Application Team
  * @brief   This code example shows how to configure the RTC in order to work
  *          with the WUT through the STM32L4xx RTC LL API.
  *          Peripheral initialization done using LL unitary services functions.
  * @attention
  * <h2><center>&copy; COPYRIGHT(c) 2017 STMicroelectronics</center></h2>
  * Redistribution and use in source and binary forms, with or without modification,
  * are permitted provided that the following conditions are met:
  *   1. Redistributions of source code must retain the above copyright notice,
  *      this list of conditions and the following disclaimer.
  *   2. Redistributions in binary form must reproduce the above copyright notice,
  *      this list of conditions and the following disclaimer in the documentation
  *      and/or other materials provided with the distribution.
  *   3. Neither the name of STMicroelectronics nor the names of its contributors
  *      may be used to endorse or promote products derived from this software
  *      without specific prior written permission.
  * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
  * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
  * IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE
  * DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT HOLDER OR CONTRIBUTORS BE LIABLE
  * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
  * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR
  * SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER
  * CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
  * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
  * OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
/* Includes ------------------------------------------------------------------*/
#include "main.h"
/** @addtogroup STM32L4xx_LL_Examples
/** @addtogroup RTC_ExitStandbyWithWakeUpTimer
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Value defined for WUT */
#define RTC_WUT_TIME               ((uint32_t)5)     /* 5 s */
/* Oscillator time-out values */
#define LSI_TIMEOUT_VALUE          ((uint32_t)100)   /* 100 ms */
#define LSE_TIMEOUT_VALUE          ((uint32_t)5000)  /* 5 s */
#define RTC_TIMEOUT_VALUE          ((uint32_t)1000)  /* 1 s */
/* Defines related to Clock configuration */
/* Uncomment to enable the adequate Clock Source */
/*#define RTC_CLOCK_SOURCE_LSE*/
#define RTC_CLOCK_SOURCE_LSI
#ifdef RTC_CLOCK_SOURCE_LSI
/* ck_apre=LSIFreq/(ASYNC prediv + 1) = 256Hz with LSIFreq=32 kHz RC */
#define RTC_ASYNCH_PREDIV          ((uint32_t)0x7C)
/* ck_spre=ck_apre/(SYNC prediv + 1) = 1 Hz */
#define RTC_SYNCH_PREDIV           ((uint32_t)0x00FF)
#endif
#ifdef RTC_CLOCK_SOURCE_LSE
/* ck_apre=LSEFreq/(ASYNC prediv + 1) = 256Hz with LSEFreq=32768Hz */
#define RTC_ASYNCH_PREDIV          ((uint32_t)0x7F)
#endif
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
__IO uint8_t ubButtonPress = 0;
#if (USE_TIMEOUT == 1)
uint32_t Timeout = 0; /* Variable used for Timeout management */
#endif /* USE_TIMEOUT */
/* Private function prototypes -----------------------------------------------*/
void     SystemClock_Config(void);
void     Configure_RTC(void);
void     EnterStandbyMode(void);
void     LED_Init(void);
void     LED_Blinking(uint32_t Period);
void     UserButton_Init(void);
void     WaitForUserButtonPress(void);
/* Private functions ---------------------------------------------------------*/
  * @brief  Main program
  * @param  None
  * @retval None
int main(void)
  /* Configure the system clock to 80 MHz */
  SystemClock_Config();
  /* Initialize LED2 */
  LED_Init();
  /* Configure RTC to use WUT */
  Configure_RTC();
  /* Check and handle if the system was resumed from StandBy mode */
  if(LL_PWR_IsActiveFlag_SB() != 1)
    /* ##### Run after normal reset ##### */
    /* Enable wake-up timer and enter in standby mode */
    EnterStandbyMode();
  else
    /* ##### Run after standby mode ##### */
    /* Clear Standby flag*/
    LL_PWR_ClearFlag_SB();
    /* Reset RTC Internal Wake up flag */
    LL_RTC_ClearFlag_WUT(RTC);
    /* Slow Toggle LED */
    LED_Blinking(LED_BLINK_SLOW);
  /* Infinite loop */
  while (1)
  * Brief   This function configures RTC.
  * Param   None
  * Retval  None
  /*##-1- Enables the PWR Clock and Enables access to the backup domain #######*/
  /* To change the source clock of the RTC feature (LSE, LSI), you have to:
     - Enable the power clock
     - Enable write access to configure the RTC clock source (to be done once after reset).
     - Reset the Back up Domain
     - Configure the needed RTC clock source */
  LL_APB1_GRP1_EnableClock(LL_APB1_GRP1_PERIPH_PWR);
  LL_PWR_EnableBkUpAccess();
  /*##-2- Configure LSE/LSI as RTC clock source ###############################*/
  /* Enable LSE only if disabled.*/
  if (LL_RCC_LSE_IsReady() == 0)
    LL_RCC_ForceBackupDomainReset();
    LL_RCC_ReleaseBackupDomainReset();
    LL_RCC_LSE_Enable();
    Timeout = LSE_TIMEOUT_VALUE;
    while (LL_RCC_LSE_IsReady() != 1)
      if (LL_SYSTICK_IsActiveCounterFlag())
        Timeout --;
      if (Timeout == 0)
        /* LSE activation error */
        LED_Blinking(LED_BLINK_ERROR);
    LL_RCC_SetRTCClockSource(LL_RCC_RTC_CLKSOURCE_LSE);
    /*##-3- Enable RTC peripheral Clocks #######################################*/
    /* Enable RTC Clock */
    LL_RCC_EnableRTC();
#elif defined(RTC_CLOCK_SOURCE_LSI)
  /* Enable LSI */
  LL_RCC_LSI_Enable();
  Timeout = LSI_TIMEOUT_VALUE;
  while (LL_RCC_LSI_IsReady() != 1)
      Timeout --;
    if (Timeout == 0)
      /* LSI activation error */
  LL_RCC_SetRTCClockSource(LL_RCC_RTC_CLKSOURCE_LSI);
  LL_RCC_EnableRTC();
#else
#error "configure clock for RTC"
#endif
  /*##-4- Configure RTC ######################################################*/
  /* Disable RTC registers write protection */
  LL_RTC_DisableWriteProtection(RTC);
  /* Set prescaler according to source clock */
  LL_RTC_SetAsynchPrescaler(RTC, RTC_ASYNCH_PREDIV);
  LL_RTC_SetSynchPrescaler(RTC, RTC_SYNCH_PREDIV);
  /* Disable wake up timer to modify it */
  LL_RTC_WAKEUP_Disable(RTC);
  /* Wait until it is allow to modify wake up reload value */
  Timeout = RTC_TIMEOUT_VALUE;
  while (LL_RTC_IsActiveFlag_WUTW(RTC) != 1)
      Timeout --;
    if (Timeout == 0)
  /* Setting the Wakeup time to RTC_WUT_TIME s
       If LL_RTC_WAKEUPCLOCK_CKSPRE is selected, the frequency is 1Hz,
       this allows to get a wakeup time equal to RTC_WUT_TIME s
       if the counter is RTC_WUT_TIME */
  LL_RTC_WAKEUP_SetAutoReload(RTC, RTC_WUT_TIME);
  LL_RTC_WAKEUP_SetClock(RTC, LL_RTC_WAKEUPCLOCK_CKSPRE);
  /* Enable RTC registers write protection */
  LL_RTC_EnableWriteProtection(RTC);
  * @brief  Function to configure and enter in STANDBY Mode.
  * @param  None
  * @retval None
  /* ######## ENABLE WUT #################################################*/
  /* Enable wake up counter and wake up interrupt */
  /* Note: Periodic wakeup interrupt should be enabled to exit the device
     from low-power modes.*/
  LL_RTC_EnableIT_WUT(RTC);
  LL_RTC_WAKEUP_Enable(RTC);
  /* ######## ENTER IN STANDBY MODE ######################################*/
  /** Request to enter STANDBY mode
    * Following procedure describe in STM32L4xx Reference Manual
    * See PWR part, section Low-power modes, Standby mode
  /* Reset Internal Wake up flag */
  /* Check that PWR Internal Wake-up is enabled */
  if (LL_PWR_IsEnabledInternWU() == 0)
    /* Need to enable the Internal Wake-up line */
    LL_PWR_EnableInternWU();
  /* Set Stand-by mode */
  LL_PWR_SetPowerMode(LL_PWR_MODE_STANDBY);
  /* Set SLEEPDEEP bit of Cortex System Control Register */
  LL_LPM_EnableDeepSleep();
  /* This option is used to ensure that store operations are completed */
#if defined ( __CC_ARM)
  __force_stores();
#endif
  /* Request Wait For Interrupt */
  __WFI();
  * @brief  Initialize LED2.
  * @param  None
  * @retval None
void LED_Init(void)
  /* Enable the LED2 Clock */
  LED2_GPIO_CLK_ENABLE();
  /* Configure IO in output push-pull mode to drive external LED2 */
  LL_GPIO_SetPinMode(LED2_GPIO_PORT, LED2_PIN, LL_GPIO_MODE_OUTPUT);
  /* Reset value is LL_GPIO_OUTPUT_PUSHPULL */
  //LL_GPIO_SetPinOutputType(LED2_GPIO_PORT, LED2_PIN, LL_GPIO_OUTPUT_PUSHPULL);
  /* Reset value is LL_GPIO_SPEED_FREQ_LOW */
  //LL_GPIO_SetPinSpeed(LED2_GPIO_PORT, LED2_PIN, LL_GPIO_SPEED_FREQ_LOW);
  /* Reset value is LL_GPIO_PULL_NO */
  //LL_GPIO_SetPinPull(LED2_GPIO_PORT, LED2_PIN, LL_GPIO_PULL_NO);
  * @brief  Set LED2 to Blinking mode for an infinite loop (toggle period based on value provided as input parameter).
  * @param  Period : Period of time (in ms) between each toggling of LED
  *   This parameter can be user defined values. Pre-defined values used in that example are :
  *     @arg LED_BLINK_FAST : Fast Blinking
  *     @arg LED_BLINK_SLOW : Slow Blinking
  *     @arg LED_BLINK_ERROR : Error specific Blinking
  * @retval None
  /* Toggle IO in an infinite loop */
  while (1)
    LL_GPIO_TogglePin(LED2_GPIO_PORT, LED2_PIN);
    LL_mDelay(Period);
  * @brief  Configures User push-button in EXTI mode.
  * @param  None
  * @retval None
  /* Enable the BUTTON Clock */
  USER_BUTTON_GPIO_CLK_ENABLE();
  /* Configure GPIO for BUTTON */
  LL_GPIO_SetPinMode(USER_BUTTON_GPIO_PORT, USER_BUTTON_PIN, LL_GPIO_MODE_INPUT);
  LL_GPIO_SetPinPull(USER_BUTTON_GPIO_PORT, USER_BUTTON_PIN, LL_GPIO_PULL_NO);
  /* Connect External Line to the GPIO*/
  USER_BUTTON_SYSCFG_SET_EXTI();
  /* Enable a rising trigger EXTI line 13 Interrupt */
  USER_BUTTON_EXTI_LINE_ENABLE();
  USER_BUTTON_EXTI_FALLING_TRIG_ENABLE();
  /* Configure NVIC for USER_BUTTON_EXTI_IRQn */
  NVIC_EnableIRQ(USER_BUTTON_EXTI_IRQn);
  NVIC_SetPriority(USER_BUTTON_EXTI_IRQn,0x03);
  * @brief  Wait for User push-button press to start transfer.
  * @param  None
  * @retval None
  while (ubButtonPress == 0)
    LL_mDelay(LED_BLINK_FAST);
  * @brief  System Clock Configuration
  *         The system Clock is configured as follows :
  *            System Clock source            = PLL (MSI)
  *            SYSCLK(Hz)                     = 80000000
  *            HCLK(Hz)                       = 80000000
  *            AHB Prescaler                  = 1
  *            APB1 Prescaler                 = 1
  *            APB2 Prescaler                 = 1
  *            MSI Frequency(Hz)              = 4000000
  *            PLL_M                          = 1
  *            PLL_N                          = 40
  *            PLL_R                          = 2
  *            Flash Latency(WS)              = 4
  * @param  None
  * @retval None
  /* MSI configuration and activation */
  LL_FLASH_SetLatency(LL_FLASH_LATENCY_4);
  LL_RCC_MSI_Enable();
  while(LL_RCC_MSI_IsReady() != 1)
  /* Main PLL configuration and activation */
  LL_RCC_PLL_ConfigDomain_SYS(LL_RCC_PLLSOURCE_MSI, LL_RCC_PLLM_DIV_1, 40, LL_RCC_PLLR_DIV_2);
  LL_RCC_PLL_Enable();
  LL_RCC_PLL_EnableDomain_SYS();
  while(LL_RCC_PLL_IsReady() != 1)
  /* Sysclk activation on the main PLL */
  LL_RCC_SetAHBPrescaler(LL_RCC_SYSCLK_DIV_1);
  LL_RCC_SetSysClkSource(LL_RCC_SYS_CLKSOURCE_PLL);
  while(LL_RCC_GetSysClkSource() != LL_RCC_SYS_CLKSOURCE_STATUS_PLL)
  /* Set APB1 & APB2 prescaler*/
  LL_RCC_SetAPB1Prescaler(LL_RCC_APB1_DIV_1);
  LL_RCC_SetAPB2Prescaler(LL_RCC_APB2_DIV_1);
  /* Set systick to 1ms in using frequency set to 80MHz */
  /* This frequency can be calculated through LL RCC macro */
  /* ex: __LL_RCC_CALC_PLLCLK_FREQ(__LL_RCC_CALC_MSI_FREQ(LL_RCC_MSIRANGESEL_RUN, LL_RCC_MSIRANGE_6),
                                  LL_RCC_PLLM_DIV_1, 40, LL_RCC_PLLR_DIV_2)*/
  LL_Init1msTick(80000000);
  /* Update CMSIS variable (which can be updated also through SystemCoreClockUpdate function) */
  LL_SetSystemCoreClock(80000000);
/*   USER IRQ HANDLER TREATMENT                                               */
  * @brief  Function to manage User button
  * @param  None
  * @retval None
void UserButton_Callback(void)
  /* Update User push-button variable : to be checked in waiting loop in main function */
  ubButtonPress = 1;
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *         where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(char *file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d", file, line) */
  /* Infinite loop */
  while (1)
#endif
/************************ (C) COPYRIGHT STMicroelectronics *****END OF FILE****/
  • \$\begingroup\$ Unfortunately I don't have an STM32L4 to run your code. You would need to check the exact differences between those two MCU models to see if any of them are related to the RTC or standby functionality. However, if the differences are not related to those areas, I would be concerned if code provided by ST wasn't working. That leads to my question: Since you are only supplying code and not schematics & hardware photos etc., how did you eliminate hardware as the potential cause of your problems? Please can you update your question with details of your troubleshooting & analysis on this point. \$\endgroup\$ – SamGibson Mar 31 '18 at 22:36
  • \$\begingroup\$ Thanks Sam. I am working on this for someone else and I'm not at liberty to provide schematics, but I had added code that shuts down hardware besides the MCU (Bluetooth, ADC, etc.) From looking at this website, it appears that the only difference between the MCU models is some added hardware (USB OTG, segment LCD driver). st.com/en/microcontrollers/… \$\endgroup\$ – user9571554 Apr 3 '18 at 8:23
  • \$\begingroup\$ I wonder if I may need to configure the appropriate interrupt somehow, but I haven't had any success trying that yet. \$\endgroup\$ – user9571554 Apr 3 '18 at 8:25
  • \$\begingroup\$ Thanks for the reply. "it appears that the only difference between the MCU models is some added hardware (USB OTG, segment LCD driver)." I assume you aren't using any of those additional modules. Therefore the concern remains that there isn't an obvious reason why the ST code doesn't work on your STM32L471RG and a hardware cause remains a possibility. Unfortunately, without a schematic & photos etc. I can't advise further, as I could easily waste hours describing troubleshooting I would perform, which would apply on some hardware, but could be impractical on your design. Sincere good luck! \$\endgroup\$ – SamGibson Apr 3 '18 at 16:23
  • \$\begingroup\$ In case other readers are interested in this topic, I found that the same question has been asked here on Stack Overflow. Although there are no answers there today, an answer might be posted there in the future. \$\endgroup\$ – SamGibson Apr 6 '18 at 19:33
