I was checking out a circuit for power management. That's when I came across this unknown component which looks so much like half a transformer and a switch. What exactly is this?
14\$\begingroup\$ Looks like a relay to me. \$\endgroup\$ – jonk Mar 30 '18 at 7:10
1\$\begingroup\$ is this regional (US)? Today I know that a zig zag line can mean a resistor, but when I learned it there were only rectangles. same here, left is what we got here, right is how I learned to draw it. \$\endgroup\$ – dlatikay Mar 30 '18 at 11:23
1\$\begingroup\$ A more common arrangement would show the coil to the left of the contacts, so you can visualize the coil pulling the moving contact toward itself when energised. \$\endgroup\$ – Peter Bennett Mar 30 '18 at 16:20
\$\begingroup\$ @dlatikay The two different resistor symbols are indeed a Europe vs US distinction. I believe a few other symbols are also different. \$\endgroup\$ – Kevin Keane Mar 31 '18 at 5:00
It appears to be a relay, which as you suggest does look a lot like a combination of half a transformer (coil) and a switch; in this case, it is a magnetically operated switch.
Some schematics seem to draw a relay with the extra parallel lines (bars) between the coil and the switch contacts, others do not, so you may not always see those two parallel lines between the coil and switch contacts. To my knowledge this looks like a regular single-throw relay, with a normally open (N/O) switch contact and a normally closed (N/C) switch contact, on either side of the common (usually marked 'C') switch contact.
When the coil is energized by a voltage being applied across it, a magnetic field forms, and this attracts the switch 'arm' away from the N/C switch contact towards the N/O switch contact. When the coil is no longer energized, the switch arm (usually with the aid of an additional spring, spring leaf, or due to the arm being formed from spring steel or similar into a spring-like shape) will return to make contact with the N/C switch contact.
Relays come in many shapes and sizes, some with many series of switch contacts that can be 'thrown' when the coil is energized, and then return to their resting positions after the coil voltage is removed.
Some particularly interesting and complicated relays were used in analogue telephone switch systems, such as these before the advent of fully digital exchanges. Sometimes telephone exchanges will still have some pieces of analogue switch gear working along side the newer digital equipment, but most exchanges are now fully digital. I worked at a British Telecom exchange for a short while in the late 1990's and they were still transitioning from the analogue exchange equipment to a fully digital fibre-exchange, and there were several floors of the building still occupied with huge equipment racks of analogue switch gear and telephone relays. It was quite a sight to behold and to hear!
Wikipedia has some great additional reading on relays too: https://en.wikipedia.org/wiki/Relay
I hope this helps, and hopefully others with more experience than I, will contribute or make corrections if I haven't explained things clearly.
4\$\begingroup\$ It's a single-pole double-throw, not single throw. Easily confused. I remember it by thinking "Pole = moving Parts" and "Throw = Things it can Touch." Also, relays (and inductors in general) are more concerned with current than voltage. May seem a pedantic point, but it's an important distinction to understand. \$\endgroup\$ – Phil C Mar 30 '18 at 7:58
\$\begingroup\$ NC = Normally closed, NO = Normally open. When the coil isn't energized, the C = Common (unmarked middle terminal) is connected to the NC terminal. When energized, the NO is connected to C, and NC is disconnected from C. \$\endgroup\$ – CSM Mar 30 '18 at 10:59
\$\begingroup\$ I believe the bars symbolize the magnetic core of the coil. If the bars are absent, it's a coil wound around air. \$\endgroup\$ – Kevin Keane Mar 31 '18 at 5:03
It's a relay. Single-pole double-throw relay, to be precise. Extremely basic and common component. A current through the coil creates a magnetic field to control the switch. Typically used to allow for circuit isolation and/or for using a low current signal to control a high current source. Wiki
\$\begingroup\$ They can also be used to replace switching transistors to a certain (and highly inefficient) extent, or to easily switch multiple circuits with a single signal. If you're interested, here's a simulation of a demo circuit I was asked to create. Mix of SPDT and DPDT relays to create an astable multivibrator 4.4Hz clock and H-bridge motor controller. \$\endgroup\$ – Phil C Mar 30 '18 at 14:42
