8
I have two node voltages that I wish to plot against each other, similar to the XY mode on an oscilloscope. How do I achieve this via LTspice? LTspice only plots quantities against time.
Assuming you are using .TRAN, go to the plot screen, right click on the x-axis label area (time, probably, right now), and change it from time to whatever node voltage or formula you want. That's all there is to it.
Follow the steps indicated by the pictures below:
  1. List item
  2. List item
  3. List item
  4. List item
That's pretty clear, I think.
  • \$\begingroup\$ Here's a link from Analog Devices with an illustration of this. -- analog.com/en/technical-articles/ltspice-parametric-plots.html \$\endgroup\$
    – Matt Egan
    Commented Mar 30, 2018 at 17:14
  • \$\begingroup\$ @MattEgan I think my description here might be almost as good as that one. ;) \$\endgroup\$
    – jonk
    Commented Mar 30, 2018 at 17:16
  • \$\begingroup\$ Ah nice! Love the illustrations you added! \$\endgroup\$
    – Matt Egan
    Commented Mar 30, 2018 at 18:55
