Some small electronic devices react to PMR446 adversely temporarily, when exposed to a PMR446 transmitter, during the transmission.
  • Portable DVD player: Green horizontal stripes on screen. Increasing if I hold the PMR446 transmitter near.
  • Portable CD player (discman): Laser lens loses track, CD spins up very fast; also indicating low battery.
  • Boombox CD player: Skips and noise hearable if too near to laser lens + fart sound at speakers.
  • Standalone DVD recorder: Nothing, surprisingly.
  • DECT unit: Display brightness decreases temporarily.
  • USB Multimeter: Display lower current than actually flowing (e.g. 1.2A instead of 1.6a). Sometimes, voltage jumps up to 9.99V (highest displayable amount).
  • CD boombox: Fart sound from speaker.
  • Toy robot: Do random moves.
  • Toy phone benign girl: Decreased speaker volume; ability to be enabled by the PMR446 signal.
  • Portable standalone LED torch gets dimmed.
How can these interferences be explained technically?
    \$\begingroup\$ Is this a proper PMR radio or a generic UHF handheld radio tuned to the PMR channels? \$\endgroup\$ – MrGerber Mar 31 '18 at 21:01
  • \$\begingroup\$ @MrGerber It is a Stabo portable PMR transmitter, Freecomm 650. Does that matter? \$\endgroup\$ – neverMind9 Mar 31 '18 at 21:05
    \$\begingroup\$ Yes, because proper approved PMR446 radios has maximum power output of 500mW, but your run of the mill Chinese UHF radio is typically 5W transmit power \$\endgroup\$ – MrGerber Mar 31 '18 at 21:08
This is electromagnetic interference.
Effectively every wire in every piece of electronics is a radio reciever to some extent. When placed next to a strong transmitter they will recieve a signal, which may be interpreted as a control signal.
Systems are supposed to be designed to minimise the effect of this, but that costs money and is often skimped on.
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
