I am working on a project using an STM32F4 nucleo board and a MLX90621 device. I have a problem regarding the communication between the two using the HAL I2C library.
The EEPROM has two devices inside, an EEPROM and the IR thermal device itself. Using the HAL library with the I2C implementation, I can read the EEPROM perfectly but I cannot read the device itself. I checked with the oscilloscope and the device does not acknowledge when I want to read it. What might be the cause?
I will attach some oscilloscope capture images below and how should they look from the datasheet. Reading whole frame: ReadIR_Real enter image description here
Lack of acknowledge:enter image description here
  • \$\begingroup\$ Can you improve the signal integrity so there is less crosstalk from SCL to SDA? Is it excessive 10:1 probe ground length of poor GND or actual crosstalk? \$\endgroup\$ Apr 1, 2018 at 19:38
  • \$\begingroup\$ I am using just one ground for both oscilloscope probe so I think that might be the problem. However, there is something else going on here. When I communicate to the EEPROM, all is good, where the Question Mark is in picture, I have an ACK. I can also see that the device is trying to ACK (I think, because it is trying to go LOW for a moment there) but for some reason it doesn't until the next clock (when it is too late). \$\endgroup\$ Apr 1, 2018 at 19:45
    \$\begingroup\$ Since SCL is on slow rising edge, signal integrity ought to be improved meanwhile fast falling edge has cross talk \$\endgroup\$ Apr 1, 2018 at 20:22
    \$\begingroup\$ Either way, the problem I think is at the transfer. When comparing my result to the ideal signal in the datasheet there is a major difference. At the transmit sequence using HAL I2C (W60, 02, 00, 04, 40) there is a STOP and a START (where the clock is streched, can be easy seen in second picture), in the datasheet there is only a (re)START. Could this affect the ability of the slave to ACK? Strange enough, the EEPROM is not affected by this. \$\endgroup\$ Apr 1, 2018 at 20:24
    \$\begingroup\$ There should be no STOP between write address phase and read phase, only extra START. I think this is your problem. \$\endgroup\$ Apr 1, 2018 at 20:38
According to I2C specifications, when so-called "combined format" is used,
there should be "repeated START" in between configuration stage (internal start and stop addresses, and the number of bytes to read) and READ function, but no STOP.
When the interface encounters STOP, it "forgets" the submitted read parameters, so the next stand-alone READ doesn't know where to read from, and NAKs.
  • \$\begingroup\$ This was indeed the problem. Modifying the HAL I2C library (specifically, the Mem_Read() function, to take more parameters than just memory location) resulted in a fix. Also, the reason why I could read the EEPROM was that you can read it whole (starting from 0x00) without transmitting anything. \$\endgroup\$ Apr 3, 2018 at 14:05
I don't know if this solves your problem, but I can tell from a lot of my own mistakes with I2C that if a slave does not ACK a request, then it's almost always because the I2C slave address is not proper. Please be aware of the fact that the last bit of the first address byte is the R/W bit and often you have to shift the address from the datasheet one bit to the left prior to putting it on the bus.
  • \$\begingroup\$ Thank you for your input! The address is fine, it is 0x60 as it can be seen in the oscilloscope data (plus the read bit is set). I have left-aligned the address as the HAL library requests and the R/W bit is automatically set. I think I will have to bit bang this. \$\endgroup\$ Apr 1, 2018 at 20:45
