I want to have the PIR Motion Sensor: https://www.adafruit.com/product/189
Used to turn on a light whenever it detects motion.
Simple enough, but would it be possible to have this done wirelessly?
I.E. PIR Motion Sensor detects motion, sends a single high to a transmitter, signal is sent to receiver, receiver has output signal to blink an LED.
Note: The transmitter and receiver will only be about 5 feet away from each other, so hopefully all of this can be low power.
Any help would be appreciated. Thank you.
(Raspberry Pi is tagged because I wasn't sure if one would be required to implement what I want)
