I am using Keil uVision5 for programming TI launchpad TM4C123GXL with TIVA WARE Library.
How can I use the Logic Analyzer and Event Viewer in Keil uVision?
While in a debug mode, I tried to set up Logic Analyzer by adding a variable which alternate 0 and 1. But the output in the analyzer shows nothing. How can I correctly setup it?
Also how can I setup the Event Viewer? I could not find any help online that can help me with TM4C123. The help window give the option to configure Cortex-M device but it does not give options for TM4C123.
  • \$\begingroup\$ If I paid Keil for their products and didn't know how to apply them, I'd probably just email or call them up and ask. Have you tried that yet? \$\endgroup\$ – jonk Apr 2 '18 at 20:52
  • \$\begingroup\$ I am using the evaluation version of Keil. I have asked the same question on ARM Community. Didn't got any response. \$\endgroup\$ – Masood Salik Apr 7 '18 at 19:56
  • \$\begingroup\$ /@MasoodSalik Did you resolve this issue? \$\endgroup\$ – Mahendra Gunawardena Jul 28 at 16:51
  • \$\begingroup\$ The issue was not resolved. However, I used an alternative technique. I pulled up a pin high at the different events, and monitor them via an external oscilloscope. \$\endgroup\$ – Masood Salik Jul 29 at 19:07
