I'm creating a LTSpice simulation. I need a voltage source that looks like the output of a full wave bridge rectifier.
The simulation includes a sine voltage source (voltage block) line to generate an "Input Voltage" and an arbitrary voltage (bv block) Rectified which uses the abs() function to "flip" the negative part of the input voltage waveform, thus creating the "Output Voltage" that drives the circuit.
Running the simulation generates an error message "Unknown symbol: line"
(Same problem if I use "V1" instead of "line" in the bv block formula.)
Help, please?
table(-1k,1k,0,0,1k,1k)
, but this is just a suggestion. \$\endgroup\$
