-1
I need to amplify voltages from range of -5mV/5mV to voltages of range -5V/5V. So I used circuit from the image.Amplifying circuit LF356N
I decided to check if it is working by connecting it to Arduino Uno to simulate signal and to power the amplifier. When checking the output voltage I found that it is 3.5V. After removing the signal, output voltage did not change, it was still 3.5V.
I am new to this kind of circuits and I cannot find the problem why it is not amplifying the signal but giving constant values. Any help would be appreciated.
  • \$\begingroup\$ Your LF356 is not specified to operate with only a 5V supply. Not even close. Read the datasheet. \$\endgroup\$ – brhans Apr 3 '18 at 14:37
  • \$\begingroup\$ Also note that the LF356 has a typical 3mV input offset voltage. Your circuit has a DC gain of 1000, so that would mean that, even if the supply was OK, you would have 3V at the output even with the non-inverting input connected to GND, because you'd be amplifying the offset. \$\endgroup\$ – freejuices Apr 3 '18 at 14:41
Read the datasheet before choosing an op-amp.
You are violating the recommended supply voltage range
and the input common-mode voltage range
