This Dual Rail-to-Rail opamp :
I implemented a circuit with this dual rail-to-rail opamp on a breadboard and used a ±15V dual supply. The outputs saturate either to negative or positive rail which I'm not expecting as outputs. In simulation everything works fine but in real I checked the wirings ten times I couldn't find the problem.
My question is regarding the following absolute max ratings for the power rails:
Does 16V above mean that the max supply rail for the opamp is
Vcc<16 and |Vee|<16V?
As I mentioned I use +15V for Vcc and -15V for the Vee. Am I exceeding limits?
