I would like to create a simple circuit from logic gates, flip-flops (no RLC components) to do the following task:
This circuit has 5 inputs (4 positive real-valued signals \$x_1, x_2, x_3, x_4\$ and a clock signal \$clk\$). The output signals \$y_1, y_2, y_3, y_4\$ are determined as follows:
At the rising edge of \$clk\$, the output signal \$y_i\$ with \$i =1,4\$ correspoing maximum input \$x_i\$ with \$x_i = max(x_1,x_2,x_3,x_4)\$ at this time will have value \$1\$ while other output signals are zero during that period.
For example, \$x_3 = max(x_1,x_2,x_3,x_4)\$ then \$y_3 =1\$ and \$y_1 = y_2=y_4=0\$.
Because I don't know how to do starting from logic gates, I tried to write verilog code and then synthesized it to get the circuit. However, I think the result is too much complicated than necessary. Components such as logic gates, flip-flops, multiplexers are OK but the comparator block is maybe too complex. Is there a simple circuit to do this task? It can be obtained from circuit design from logic gates or synthesized from verilog.
Input signals \$x_1, x_2, x_3, x_4\$ are positive real-valued signals but I don't need high precision, only about 3 significant figures are OK.
Below is my code and the circuit obtained from this code.
module example (clk, x1, x2, x3, x4, y1, y2, y3, y4);
input clk, x1, x2, x3, x4;
output reg y1, y2, y3, y4;
always @(posedge clk)
if((x1>x2) && (x1>x3) && (x1>x4))
begin
y1 <= 1'b1;
y2 <= 1'b0;
y3 <= 1'b0;
y4 <= 1'b0;
end
else if((x2>x1) && (x2>x3) && (x2>x4))
begin
y1 <= 1'b0;
y2 <= 1'b1;
y3 <= 1'b0;
y4 <= 1'b0;
end
else if((x3>x1) && (x3>x2) && (x3>x4))
begin
y1 <= 1'b0;
y2 <= 1'b0;
y3 <= 1'b1;
y4 <= 1'b0;
end
else if((x4>x1) && (x4>x2) && (x4>x3))
begin
y1 <= 1'b0;
y2 <= 1'b0;
y3 <= 1'b0;
y4 <= 1'b1;
end
endmodule
Schematic obtained from the code above:
x
inputs are 1? \$\endgroup\$x
s are "real valued" but the way you coded it, they will be assumed to be 1 bit digital values. Verilog doesn't have any "real" numbers, so you'll need to have an external ADC and get the input to this module as fixed-point digital values (unless you want to develop or buy a floating point IP block). \$\endgroup\$x1
,x2
, etc., as 1-bit digital values. \$\endgroup\$
