In my Propeller project, I have the following devices, with the related pins:
- DS1302 RTC
- SClk - IO - CE
- Micro SD Card
- SClk - CD - CS - DI - DO
- SPI SRAM x 2
- SClk - SO - SI - CE
- PS2 Mouse
- Clock - Data
- PS2 Keyboard
- Clock - Data
- Eprom
- SCL - SDA
Right now, each one of these is individually allocated a Clock Pin, What I would like to know is if I can merge all of the clock pins into 1 single pin And re-use the other spare pin for extra devices?
Even if I need to introduce a transistor to boost the signal (So I am guessing, this is what may happen that there is not enough signal to service all the devices and I need a transistor? - I don't know I'm just guessing since I have no formal grounding in electronics)
For reference, This is the link to an earlier post (different question) on stack electronics which shows my actual circuit/schematic
https://i.stack.imgur.com/pdCgo.png
Thank You
