Looking at this USB Hub controller IC, XR22404, page 5. More confused on the second statement, what does it mean to be asserted for a min of 10 us?
  • \$\begingroup\$ S = siemens. s = second. \$\endgroup\$
    – winny
    Commented Apr 5, 2018 at 7:54
  • \$\begingroup\$ I think that is one of the reasons I was confused. I suspect they made the mistake of using S instead of the traditional s for seconds. \$\endgroup\$
    – A.S.
    Commented Apr 5, 2018 at 8:22
It means if you want to reset the chip correctly, you can't just assert the reset signal for 5 us, or 7 us, or 9 us. You have to assert it for at least 10 us, or the device might not reset, or might not reset correctly.
    \$\begingroup\$ Also, just for clarity (the OP may not understand this), it must be held to within the limit range of \$V_\text{LOW}\$ -- which is what "active low" means. "Asserting it" means "active" and in this case "active" means "LOW." \$\endgroup\$
    – jonk
    Commented Apr 5, 2018 at 5:35
  • \$\begingroup\$ This can be controlled by either a Raspberry PI GPIO pin or a pull-up resistor with a grounding switch correct? When the pin is grounded is when the reset occurs? \$\endgroup\$
    – A.S.
    Commented Apr 5, 2018 at 5:36
  • \$\begingroup\$ Do the RPi outputs meet the input level requirements of the other chip? (I have no idea if RPi has 3.3 or 5 V I/Os) If they do, you should be able to hook the RPi GPIO directly to this chip. \$\endgroup\$
    – The Photon
    Commented Apr 5, 2018 at 6:05
