I'm designing a board with a control port. The control port allows an external controller to reboot the system by pulling the BRD_RESET
low, effectively restarting both regulators.
However it is possible to use an external DC power supply (5-12V) instead of the USB bus voltage provided by the control port.
In this case I could fry my external controller (5V system) because the BRD_RESET
is pulled high to the external supply voltage (5-12V) by R1
How can I protect my external controller? I need to limit the voltage it's seeing on BRD_RESET
to VBUS
and at the same time allow it to pull down BRD_RESET
to GND
