I've been trying, and failing, to find a USB RF tranceiver that I can program or that has an API I can use. Does anyone know if such a thing exists, or suggest how I could about creating one?
  • \$\begingroup\$ What is "an API I can use"? \$\endgroup\$
    – stevenvh
    Jul 27, 2012 at 11:59
  • \$\begingroup\$ @stevenvh: An Application Programming Interface. It's usually more relevant to software than hardware, but GFX cards have been implementing them over the last couple of years. \$\endgroup\$
    – hellsgate
    Jul 27, 2012 at 12:09
  • \$\begingroup\$ Yes I know what an API is, but it's a term so wide that it doesn't mean anything without specifying: what's the target development environment? \$\endgroup\$
    – stevenvh
    Jul 27, 2012 at 12:12
  • \$\begingroup\$ @stevenvh: Preferably Python (if that's what you mean). I'm looking to be able to write software to send instructions via RF to a device which will convert those instructions to physical movement. And sorry if I came across as trying to teach my granny to suck eggs :) \$\endgroup\$
    – hellsgate
    Jul 27, 2012 at 12:18
  • \$\begingroup\$ Does Python imply that the API is hardware and OS independent? I guess the API will be a shell on top of a driver, and these are platform specific. Please add anything that could be relevant for us to the question. \$\endgroup\$
    – stevenvh
    Jul 27, 2012 at 12:21
Connect a suitable RF transceiver (I'm using the cheap nRF24L01+ modules that are available on Ebay) to a USB MCU, such as a PIC18F14K50.
  • \$\begingroup\$ Thanks. Having had a search for nRF24L01+, I've now found some devices that show potential. \$\endgroup\$
    – hellsgate
    Jul 27, 2012 at 14:26
  • \$\begingroup\$ @hellsgate would you mind providing links to whatever solution you ended up with? \$\endgroup\$
    – Zero3
    Jan 8, 2015 at 17:06
Theres are many rf modules available with RS232 interface .You can buy these and connect them through a usb to RS232 converter.
