I am working on getting an art project with poor documentation back into working shape, and as part of that I'd like to identify some of its electrical connectors so I can purchase some interoperable parts. I've looked through image-based catalogs in Digi-Key and tried browsing Molex's catalog without success.
There are two that are giving me trouble at the moment:
5-pin connector
(I recognize that this connector is being used as a 4-pin device…I don't know the original design intent but they likely didn't want this one to be interoperable with the other connector listed.)
5-pin connector side view:
5-pin side
5-pin connector front view:
5-pin front
4-pin connector
4-pin connector side view:
4-pin side
4-pin connector front view:
4-pin front
Any leads (including useful search services) much appreciated!
  • \$\begingroup\$ Those connectors look mangled. I'd consider replacing them. \$\endgroup\$ Apr 5 '18 at 23:05
  • \$\begingroup\$ @IgnacioVazquez-Abrams I may well do so—but would prefer to replace with the same type if possible. (Hence the identification question.) \$\endgroup\$
    – R Zach
    Apr 5 '18 at 23:07
  • \$\begingroup\$ Maybe Molex Power Connector? \$\endgroup\$
    – Tyler
    Apr 6 '18 at 0:06
  • \$\begingroup\$ @Tyler Molex is a manufacturer, not a type of connector. And no, this clearly isn't the 4-pin MATE-N-LOK power connector that most people think of when they hear "Molex connector". \$\endgroup\$
    – user39382
    Apr 6 '18 at 0:42
  • \$\begingroup\$ it is a 5 pin version of this parts-express.com/pedocs/specs/Molex%2015%20way%20092-566s.pdf .... it appears to be obsolete \$\endgroup\$
    – jsotola
    Apr 6 '18 at 1:50
here is something similar
comes in 1 to 10 contact versions
https://www.molex.com/molex/products/family?key=econolatch&channel=products&chanName=family&pageTitle=Introduction&parentKey=wire_to_wire_connectors
this one is closer
https://www.molex.com/molex/products/datasheet.jsp?part=active/0003091042_CRIMP_HOUSINGS.xml
https://www.molex.com/molex/products/datasheet.jsp?part=active/0003091052_CRIMP_HOUSINGS.xml
  • \$\begingroup\$ Yep, I think you found the match. Thanks for your help here! \$\endgroup\$
    – R Zach
    Apr 8 '18 at 14:13
Reiterating whats already been said but personally I would replace the connectors with anything that resembles the connectors currently on the project and document the changes appropriately so the project can be easily maintained.
A suggestion to help finding a replacement part as well... try posting front view images (last image posted) with both metric and imperial tape measures showing dimensions. This will help people recognise conductor fitting diameters and conductor fitting spacings... hope this helps ! :)
  • \$\begingroup\$ I am working at a borrowed workspace with very few tools, and was lucky to even find an imperial tape measure. But yes, you're right, having fiducials in both systems is best if possible. \$\endgroup\$
    – R Zach
    Apr 8 '18 at 14:14
They look much like the nylon connectors make by AMP (now TE/AMP) and Molex for many years. Molex makes ones that look just like yours in fact. Both AMP and Molex will have their names molded into them but they may be hard to see. These days there are probably a number of numbers of companies out of China that make ones just like yours.
  • \$\begingroup\$ I looked carefully but didn't end up finding any markings on the parts other than the [1] and [4] pin identifiers that @jaysotola 's answer includes. Either mine was a knockoff part, or I couldn't see the logo because it was white on white. \$\endgroup\$
    – R Zach
    Apr 8 '18 at 14:17
  • \$\begingroup\$ The Molex ones I have have "Molex" on the "ears". \$\endgroup\$ Apr 8 '18 at 17:35
This site is temporarily in read only mode and not accepting new answers.
Not the answer you're looking for? Browse other questions tagged .
