I have an application where I have multiple PCBs connected to each other where each board edge is 45 degrees to the mating board. There are plenty of right angle connectors and straight connectors, but has anyone ever used 45 degree connectors? I have very low constraints in the connector, a simple 0.1" pitch 3 pole header is sufficient.
I am essentially looking for a product in between these two P/Ns (as an example): M20-9960345, M20-9990345
Another note is that I am aware that I could manually bend a straight connector to 45 degrees to accomplish this, but this would be for production so I would like an off-the-shelf solution.
Thanks!
