Hi guys I'm writing an electronics circuit simulator and I need a very simple and straightforward model for a field-effect transistor (as simple as the Ebers-Moll model for a BJT). I can use resistors, voltage sources, current sources, diodes, (I can also use a resistor with a very large resistance to measure the gate-source voltage).
What model would you suggest?
  • \$\begingroup\$ What has google turned up? \$\endgroup\$ – Andy aka Apr 9 '18 at 8:33
  • \$\begingroup\$ Use a voltage-controlled-current-source. And some capacitances from gate to source, and gate to drain. \$\endgroup\$ – analogsystemsrf Apr 9 '18 at 17:07
  • \$\begingroup\$ Andy aka Literally the only model I found was the hybrid-PI model adapted for FET. It contains too many variables for my taste and even for BJT doesn't actually work. \$\endgroup\$ – nc404 Apr 9 '18 at 18:15
  • \$\begingroup\$ analogsystemsrf Ok, what would be the relationship between the current and the voltage, then? How exactly would the components be placed? \$\endgroup\$ – nc404 Apr 9 '18 at 18:17
