Does anyone know of a transparent conductive paint? I am creating some home made electroluminescent panels and I need something what would work with water based polyurethane. Ive had some luck with PEDOT:PSS but I don't like the blue tint it gives and it has a tendency to pool over the polyurethane I am using for the layers under the PEDOT:PSS.
\$\begingroup\$ ITO? But I expect it has similar limitations to what you're already using. \$\endgroup\$– The PhotonCommented Apr 9, 2018 at 2:11
\$\begingroup\$ Indium, Yag doped polymer film ? PPy-DBS with PV-dF? \$\endgroup\$– D.A.S.Commented Apr 9, 2018 at 2:48
\$\begingroup\$ How would I use ITO? Could I just mix it with polyurethane? \$\endgroup\$– AnodosCommented Apr 9, 2018 at 3:35
Add a comment
