For my birthday I got a small NSOP-A Microcontroller in a kit and I was wondering if I could use it to convert analog signals to 8-bit digital signals for My raspberry pi. Anyway, that isn't the question. I was looking to see how to program it and I could not find any documentation on what sort of architecture it used. The Microcontroller I'm using is the HT46f47e(made by holtek).
What type of chip is it? And how would I program it?
    \$\begingroup\$ Datasheet at holtek.com.tw/productdetail/-/vg/46f4xe \$\endgroup\$ Apr 9, 2018 at 11:41
    \$\begingroup\$ Holtek provides a free toolchain for its 8-bit MCUs. \$\endgroup\$
    – filo
    Apr 9, 2018 at 11:46
  • \$\begingroup\$ It seems to be a proprietary core (not ARM, not 8051, ...) But all the information you're looking for can be found on Holtek's site: the MCU datasheet (including pinout, architecture, memory model, I/O registers, instruction set, ...), the type of programming hardware you need, the toolchain, development environment, ... \$\endgroup\$
    – dim
    Apr 9, 2018 at 11:55
The HT46f47e made by Holtek is a 8-bit high performance RISC architecture microcontroller. Designed especially for applications that interface directly to analog signals, such as those from sensors. (http://www.holtek.com/productdetail/-/vg/46f4xe)
The main Features are:
  • 13 to 23 bidirectional I/O lines
  • External interrupt input shared with an I/O line
  • 8-bit programmable Timer/Event Counter with overflow interrupt and 7-stage prescaler
  • On-chip crystal and RC oscillator
  • Watchdog Timer function
  • PFD for audio frequency generation
  • Power down and wake-up functions to reduce power consumption
  • Up to 0.5us instruction cycle with 8MHz system clock at VDD=5V
  • 4 or 6-level subroutine nesting
  • 4 channels 8 or 9-bit resolution A/D converter
  • 1 or 2 channel 8-bitPWMoutput shared with I/O lines
  • Bit manipulation instruction
  • Table read instructions
  • 63 powerful instructions
  • All instructions executed in one or two machine cycles
  • Low voltage reset function
  • Flash program memory can be re-programmed up to 100,000 times
  • EEPROM data memory can be re-programmed up to 1,000,000 times
  • Flash program memory data retention > 10 years
  • EEPROM data memory data retention > 10 years
  • ICP (In-Circuit Programming) interface
  • Range of packaging types
One of the possibles programmers is the EIC-300 of Holtek.
http://www.elektronik-labor.de/Holtek/Holtek7.html
  • \$\begingroup\$ How would I program it using a raspberry pi without external hardware? \$\endgroup\$ Apr 9, 2018 at 12:02
    \$\begingroup\$ "8-bit high performance" sounds rather contradicting. "High performance" as in "at least it is faster than 8051" seems more accurate. \$\endgroup\$
    – Lundin
    Apr 9, 2018 at 12:03
  • \$\begingroup\$ @BobWillett Rasp PI has nothing to do with this MCU whatsoever. \$\endgroup\$
    – Lundin
    Apr 9, 2018 at 12:04
  • \$\begingroup\$ @Lundin aww.... I'll have to shed some cash \$\endgroup\$ Apr 9, 2018 at 12:05
  • \$\begingroup\$ Is it possible to do it without any external hardware? \$\endgroup\$ Apr 9, 2018 at 12:06
