I am relatively new to electronics.
I have this power supply. It is symmetrical because I need negative voltages to other parts of the circuit. The power supply input J3 receives 18 VDC. The 7806 and 7906 are working perfectly and the voltages measured there are 6.0V and -5.98V.
On another part of the circuit, I have this amplifier, using the IC TEA2025B. Because I am using a symmetric power supply that is derived from a VDC power supply, I am not sure what I should connect to V+, virtual GND or V-.
I have marked all points I don't know in blue, from 1 to 15 and at the end of this question I will show how I connected that.
First notice R1, R2, R5 and R6. I am using that to add a DC voltage to the audio, to shift it to the middle of the rail.
This is how I have connected it:
- to virtual GND
- to virtual GND
- to +6V
- to virtual GND
- to virtual GND
- to +6V
- to -6V
- to -6V
- to -6V
- to -6V
- to -6V
- to -6V
- to -6V
- to -6V
- to virtual GND
But I am hearing an "helicopter sound", something like a feedback and as I increase the volume the pitch gets higher...
I have tried to connect these points differently but none works correctly.
How should I connect these 15 points? I think the problem comes from these 15 points incorrectly connected.
Unfortunately I do not have an oscilloscope, just a multimeter.
Thanks in advance.
