In the above circuit, using KVL loops I'm getting the correct answer, \$ Va = 24V \$
However using KCL I am stuck at writing an expression for \$ i_1 \$ because of the voltage source in series with the resistor. Is below expression correct ? $$i_1 = (0-Va)/12 $$
Those 60V sources are throwing me off. Appreciate any help. Thanks!
    \$\begingroup\$ I1 = (V1 - Va)/R1 = (60V - Va)/12Ohm \$\endgroup\$
    – G36
    Apr 10, 2018 at 15:27
  • \$\begingroup\$ @G36 Ahh I see ty :) What if we swap the places of 60V and R1 ? then how to write I1 ? (I've edited the circuit to show this..) \$\endgroup\$
    – AgentS
    Apr 10, 2018 at 15:33
    \$\begingroup\$ @rsadhvika Then you'd mentally swap it back to keep things easier. Or just assign i1 to the current in V1. Or else you'd use a bizarre (and technically completely unnecessary) idea called supernodes. KCL is used by nodal analysis. Are you aware of the nodal analysis approach? \$\endgroup\$
    – jonk
    Apr 10, 2018 at 15:58
  • \$\begingroup\$ @jonk ty :) I'm familiar with nodal analysis, no expert though. Never heard of supernodes. I'll look it up.. For now I feel happy as I figured out a dirty way to find i1 : Let's say Vb is the voltage on the left edge of R1. Then i1 = (0-Vb)/12 and Va = Vb+60. \$\endgroup\$
    – AgentS
    Apr 10, 2018 at 17:56
  • \$\begingroup\$ @rsadhvika See if the answer helps any. \$\endgroup\$
    – jonk
    Apr 10, 2018 at 19:13
Since you are "familiar with nodal analysis," I'll approach your question from that perspective. Let's draw this up two ways:
(We'll assume that you can specify values for the three resistors and the two voltage sources.)
In the left schematic, the values of \$V_A=V_1\$ and \$V_B=V_2\$ are known, since you have them already referenced from the ground reference, directly. So the solution for \$V_X\$ using KCL (nodal analysis here) is:
$$\frac{V_X}{R_1}+\frac{V_X}{R_2}+\frac{V_X}{R_3}=\frac{V_A}{R_1}+\frac{V_B}{R_2}+\frac{0\:\text{V}}{R_3}$$
Note the symmetry here. The voltage at \$V_X\$ drives a current outward through each of the three resistors. But this must equal the current inward arriving through each of those three resistors from the other sources. But you are probably more familiar with this:
$$\frac{V_X-V_A}{R_1}+\frac{V_X-V_B}{R_2}+\frac{V_X-0\:\text{V}}{R_3}=0\:\text{A}$$
Note that there is no difference. These two above equations are identical. And they solve out as:
$$V_X=R_3\:\frac{R_1\:V_2 + R_2\:V_1}{R_1\:R_2 + R_1\:R_3 + R_2\:R_3}$$
But you could also have solved this as a resulting central voltage, given voltage sources with series impedances. The general equation is:
$$V_X=\frac{\sum_{i=1}^N \left[V_i\cdot \prod_{j=1,j\ne i}^N R_j\right]}{\sum_{i=1}^N\left[\prod_{j=1,j\ne i}^N R_j\right]}$$
In this case, that would turn into:
$$V_X=\frac{V_1\:R_2\:R_3 + V_2\:R_1\:R_3 + 0\:\text{V}\:R_1\:R_2 }{R_1\:R_2 + R_1\:R_3 + R_2\:R_3}=R_3\:\frac{R_1\:V_2 + R_2\:V_1}{R_1\:R_2 + R_1\:R_3 + R_2\:R_3}$$
Same result.
Mostly, I just want to point out that there are lots of ways to approach the left side schematic. Keep your mind flexible. Look at things in different ways and find the equivalent approaches.
To the right side schematic now. Nodal analysis would make you write two equations now, instead of one. \$V_B=V_2\$, so we don't need to worry about node \$V_B\$. But we do now have to worry about a new unknown, \$V_A\$. I have to choose a direction for the current in \$V_1\$ and I'm going to say that it is flowing from (-) to (+), or that it is pointing inward relative to \$V_X\$. So:
$$\begin{align*}\frac{V_X}{R_2}+\frac{V_X}{R_3}&=I_{V_1}+\frac{V_B}{R_2}+\frac{0\:\text{V}}{R_3}\\\\\frac{V_A}{R_1}+I_{V_1}&=\frac{0\:\text{V}}{R_1}\end{align*}$$
But \$V_A=V_X-V_1\$, so:
$$\begin{align*}\frac{V_X}{R_2}+\frac{V_X}{R_3}&=I_{V_1}+\frac{V_B}{R_2}+\frac{0\:\text{V}}{R_3}\\\\\frac{V_X-V_1}{R_1}+I_{V_1}&=\frac{0\:\text{V}}{R_1}\end{align*}$$
Solving these simultaneously (or solving the 2nd equation for \$I_{V_1}\$ and substituting that into the 1st equation) will provide the same answer as before:
The difference here is that you had to create a variable for the current (unknown, just yet) of \$V_1\$ and you had to recognize that there is a very direct relationship then between \$V_X\$ and \$V_A\$ that is created by the fact that there is a voltage source holding them apart by a fixed value.
It's an extra step. But the answer is the same.
The actual circuit is the same complexity, regardless. But being allowed to call a node "ground" and assign it the special value of \$0\:\text{V}\$ provides one way to help simplify the equations a little. And sometimes, if you move things around (without materially changing the circuit topology) you can simplify them a little more. But regardless of how you approach it, if the question being asked isn't changed and if the circuit remains equivalent, the same results should be obtained.
Following Ohm's law: \$V=IR\$ so that \$I=\frac{V}{R}\$
\$i_1=\frac{60-V_a}{12}\$
\$i_2=\frac{60-V_a}{12}\$
\$i_3=\frac{V_a-0}{4}\$
KCL: \$i_1+i_2 = i_3\$
solve for \$V_a\$, which gives \$V_a=24\$
