I need your help because I do not know much about electromagnetics.
I use Arduino UNO for control blinking LED(Cree CXA 1512 18v) fast(< 100KHz). Until now, i have used following circuit.
My project is changing micro controller Uno to RPI 3. However, If i just change it, circuit doesn't work. I think that the reason is RPi's GPIO output voltage is 3.3v. (And Arduino Uno is 5v, right?)
  1. Why this circuit doesn't work?
  2. So what should I do to make the circuit work with the RPI?
  3. I think i should change the MOSFET, do you have any product to recommend?
  4. And there are any other problems? (such as safety? I always afraid about electric shock....)
Yes, the reason is RPi's GPIO output voltage is 3.3v, and your mosfet is not designed for 3.3V logic level driving.
Replace the mosfet with one that has a vgs on of under 3.3V, replace it with a NPN transistor so you can use current instead of voltage to turn it on, or use a mosfet driver cricuit, like a 2n3904 npn to turn on and off the mosfet from your RPi with a higher voltage.
You can use NTD5865 for switching with Pi. It works with 3.3V drive voltage.
