I have designed a 50 Ohm microstrip line. Following is an image of it.enter image description here
This is drawn in Eagle. Two layer PCB. Blue plane is the ground plane. The dimensions are:
  1. Width: 1250 micrometers
  2. Thickness: 1 oz
  3. Height (between ground plane and microstrip): 700 micrometers
Dielectric is FR-4. Frequency is 1575MHz. These parameters yield 50 Ohm impedance.
You see, the problem is that the end of the microstrip is too wide that it almost contacts the pins of the IC. Is it possible the narrow down the width around that area while maintaining the 50 Ohm impedance of the microstrip?
Here is the updated layout, based on the suggestions. enter image description here
  • \$\begingroup\$ Related: Why do characteristic impedances matter only when traces are longer than half a wavelength? \$\endgroup\$
    – The Photon
    Apr 10, 2018 at 20:27
    \$\begingroup\$ Also that closely spaced track will disturb the microstrip Z0. \$\endgroup\$
    – The Photon
    Apr 10, 2018 at 20:35
  • \$\begingroup\$ sub-optimal layout and lossy FR4? How slack are your s-parameters? what tolerance Er?? \$\endgroup\$ Apr 10, 2018 at 20:35
  • \$\begingroup\$ Why are you blatently ignoring the recommended features of the IC antenna port layout? and feeding a ground loop on top with no micro PTH's? \$\endgroup\$ Apr 10, 2018 at 20:54
    \$\begingroup\$ You'll need vias between the GND pins of the IC and the ground plane. \$\endgroup\$ Apr 10, 2018 at 21:51
Is it possible the narrow down the width around that area while maintaining the 50 ohm impedance of the microstrip?
Narrowing the trace will increase its inductance (per unit length), which will increase the characteristic impedance \$Z_0\$. But you could cut out the ground plane beneath the chip's pad and a few 100 um of trace to reduce the capacitance to compensate. Doing this correctly might require optimizing the design using a 3D EM solver tool.
More realistically, though, consider that the wavelength corresponding to 1.6 GHz is somewhere between 90 and 190 mm, depending on the transmission line geometry (and the substrate Dk). A short mismatched stub of 4 or 5 mm at the end of your track is not likely to noticeably impact the return loss seen looking into the chip, so it's reasonable to just narrow the trace for a short distance and then connect it to the matched trace.
Your layout:
enter image description here Yours W=1250 H=700 G= (deleted) Er=? 4.5 \$\delta\$=? 0.1? Recommended Layout enter image description here
If you choose dual ground strips on either side of signal then the N$12 track W can reduce in width. e.g. W=850 H=700 G=200 um 50 Ohm
If you change thickness(H) W/H/G ratio changes but with only W and no coplanar GND tracks then W/H ~ 2:1 for 50 Ohms for Er=4.3
and W/H= 1.3/0.7 ratio for Er=4.6 at this f and 2 layer 1oz
Hardware Integration Guide
You may want to choose adding L in layout for an active antenna option.
  • \$\begingroup\$ Thanks for your time! I should have mentioned that I'm going to use a passive antenna. AFAIK, What you are suggesting here is to use a coplanar waveguide which seems to decrease the width greatly. However, adding a short mismatched stub at the end actually fixes the width problem. For the record, I did go through the same integration guide myself. \$\endgroup\$
    – zeke
    Apr 11, 2018 at 0:24
  • \$\begingroup\$ ok but your coplanar layout and lack of microvias or Er value and substrate specs must have fooled me. \$\endgroup\$ Apr 11, 2018 at 0:28
  • \$\begingroup\$ the 2 coplanar tracks may be wider for microvias, next check/compare pad size and holes. \$\endgroup\$ Apr 11, 2018 at 0:33
