I'm drawing the Board Shape of my board and one of the corners the connection has an angle other than 45°. Altium is not allowing me to make the connection, does anyone know how to solve this?
It is unclear exactly what you mean by "has a different angle of 45°". Do you mean "has an angle other than 45°"? If so, while drawing the line press shift-space a few times until you get the "any angle" option. This will allow you to draw the line at any angle (not restricted to 45 degrees).
1\$\begingroup\$ First of all, apologies for my English. Thanks for the answer, it worked. \$\endgroup\$ Apr 11, 2018 at 18:54
You Can set the Angle in Design> Rules > Routing Corner > Set the angle you can Set the angle you want other than 45 degree
