I would like to modulate in amplitude the upper and lower sides of a carrier with two distinct signals. Would it be possible? There is a specific name for this scheme of modulation?
The detection will be made using the sampled data (in the digital domain).
    \$\begingroup\$ Sure, probably not going to be easy though. Probably would use two single sideband transmitter circuits synchronized to the same carrier signal. \$\endgroup\$
    – C_Elegans
    Apr 11, 2018 at 20:09
  • \$\begingroup\$ what will DC blocking do to the result? \$\endgroup\$ Apr 12, 2018 at 4:34
  • \$\begingroup\$ I think I should have said upper envelope and lower envelope modulation, as upper and lower carrier trend to direct the answers to sidebands topic. \$\endgroup\$ Apr 12, 2018 at 12:58
Yes, look for ISB modulation (Independent side band modulation), the military used to do it carrying two separate message streams on the two sidebands.
I am not sure there is much benefit these days, but it is not much of a problem to do, two phasing method modulators and just sum the output before up conversion, easy.
